Crowbar Circuit To protect Sensor for overvoltage
LowQCab
Joined Nov 6, 2012
5,102
nd the resistance remains the same?
The Resistor is just to pull the Gate-Voltage to ~zero when the Zener is not conducting.
It has only a very slight effect on the operation of the Circuit.
A FET with a "Logic-Level" Threshold-Voltage-rating will have
more Gain, and therefore a sharper-response, instead of a smoother/softer response,
but in your case a sharp-response is not really required.
If you use the FET Circuit, you must verify the Clamping-Voltage by actual measurement.
Don't just guess at it.
Look at the "Gate-Charge vs Gate-to-Source Voltage" Graph in the Data-Sheet of
which ever FET you choose, the Gate-Voltage where the line goes "flat" is
the exact "Gate-Threshold" number that you should use for your calculations.
The IRLI3705N is a 55-Volt, 52-Amp, Full-Pack-Package, Logic-Level-FET,
which has a Threshold-Voltage of only ~3.5-Volts,
and does not require an Insulator-Kit for mounting, just thermal grease.
40-Volts minus 3.5-Volts = 36.5-Volts Zener-Diode required.
39.5-Volts minus 3.5-Volts = 36-Volts Zener-Diode required.
IgnacioMorac
Joined May 30, 2021
39
Here in Costa Rica I found an interesting transistor.
So
36-Volts Zener-Diode + 3.8 Volts = 39.8-Volts
IgnacioMorac
Joined May 30, 2021
39
Today I did the first test of the PCB with the circuit and it did not work. It was quite frustrating.
I have an impedance matching problem.
When I measure the voltage that comes out of the zener regulator, it is very low compared to the value presented in simulation.
I don't know whether to use an impedance decoupling stage between the voltage regulator and the U3A amplifier.
Here is the PCB
When I measured the voltages with the voltmeter, I got 1 volt at the output of the resistor array that generates 5 volts.
Maybe you are going to tell me, that the Ian Solution its is better, but the project its advanced.
click_here
Joined Sep 22, 2020
548
(25V-1V)/1k = 24mA
Looking at the graph in the LT1490 datasheet, the device needs around 35mA, and the zenar would not be getting enough current to regulate (Izt=14mA).
It's basically a case of not enough current - Try lower values for R6
IgnacioMorac
Joined May 30, 2021
39
(25V-1V)/1k = 24mA
I am seeing that I am not reaching the minimum for a little but it is valid
Ian0
Joined Aug 7, 2020
13,279
(25V-1V)/1k = 24mA
Nonsense - it needs 100uA - "SUpply current per amplifier" = 50uA towards the bottom of page 3.
Is the zener in back-to-front? That would give about 1V.
Ian0
Joined Aug 7, 2020
13,279
Here is the PCB
Could you put your measured voltages on the diagram above, please.
And include the MOSFET gate and drain voltages.
