Creative Inspire Sound system T3030
R!f@@
Joined Apr 2, 2009
10,014
i happened to chance upon this thread when i dug out my i-trigue 3000 only to find the remote missing. just curious if its possible to build a remote for it using the info gathered from this thread??
i'm a newbie to circuits and all but am confident that i can do basic soldering and building a new wired control from scratch.
its using the same connector pin but im not sure if creative used the same pin out for this 2 models. any tips on how to check pin out on the amplifier?
Open a new thread...do not hijack others.
Post pictures and I will help u.
R!f@@
Joined Apr 2, 2009
10,014
Gopal...
Mind u tht the switch is the box, the little bugger came off in the last minute.
Solder it if u need it. Hope u remember where to.
ci139
Joined Jul 11, 2016
2,037
I think both the chips in the creative circuit board are burned.
by normal conditions such is very unlikely unless you try to emit sound waves on a short circuit (!Hot Plugging unplugging the very speakers) or over drain your power amp (! long period full amplitude critical frequency square wave? // have lowwer impedance than your OUT specifies speakers attached (you can't parallel output speakers) )
burned - is not a good option to be left unnoticed (you must at least allocate a module that is the cause for - it's also possible that your mains have frequent spikes (moder-n PSU have usually some sort of input filters - but it's never shure how bad input they can "filter out") or longer over/under voltage - under voltage also can be dangerous with heating elements or inductive loads because the power lines get more current than what they're ment to withstand ...)
R!f@@
Joined Apr 2, 2009
10,014
Why are you replying to a 4 year old thread ?
Didn't you notice that the problem was solved.
ci139
Joined Jul 11, 2016
2,037
likely clicked on Related Forum Posts: at some other thread - and didn't examined the time tags :eek:
. . . . . . . . :confused: . . . . . . . . i . . . :eek: . . . . . . . donno . . . . . . . . . . :confused: . . . . . . . . . . . .:eek:
. . .:confused:. . . . . . . :eek: . . . . . which . . . . :confused: . . . . . .way . . . . . :eek: . . . . 2 . . . . . . . . :confused:
. . . . :eek: . . . . .run . . . . . . :confused: . . . . . now . . . . .. :eek: . . . . . :confused: . . . . panic! . . . . :eek:
. . :confused: . . . panic! . . . . . :rolleyes::p
