I've just connected 8 of the 15 digits:
"Away" score = 2 digits + "Home" score = 2 digits + countdown timer = 4 digits. I've connected these via the PWM circuit.
The digits work perfectly - the off digits are not dim - they're off.
Only problem at the moment is that my timer doesn't reset to all numbers. When I reset it, it should toggle through the times 45 minutes, then 40, 35, 30, 25 and back to 45 again. It seems however to jump around in different orders. I'm guessing its something to do with the reset being triggering more than once with a single press of my remote control. I'll have to look into it later.
As far the mosfet, it's warm to touch. When on full brightness (with 8 out of 15 digits working so far) it's quite warm, but still holdable in my finger tips. The heatsink will dissipate the temperature, but is it ok running that hot (when I have 15)? Should I run the current through 2 of these mosfets in parallel? or is that even possible?
Post edited:
Just found out the problem with countdown not resetting properly. I'm running all the circuits now at 5V. At this voltage, the countdown timer jumps. I increased to 6.5V and it works perfectly. However then I found the score jumped up by 2's instead of 1's. I can't win!!!
Post edited:
