Greetings,
There are a few of the PIC DVM found on the web using a PIC16F676. They are designed to drive seven segment LED displays. I have been aiming to attempt to build one to output decimal instead of seven segment in order to drive a set of edge-lit displays. The only example of such a circuit uses the rare and obsolete CA3162e Intersil IC (A/D converter) and a 74HC145 (BCD to Decimal driver) in the image below:
The aim was to create a more modern version of this using the PIC micro. The PIC16F676 doesn't have enough I/O pins to handle ten LED's in a row. The Microchip search tool led me to the PIC16F1826 as it has enough I/O's and has a 10bit A/D converter. But looking at the C code for the 676 DVM, it is using 2 byte HEX to build the segment patterns for seven segment displays. I wasn't certain that this would work so easily for ten LED's as I ended up creating 3 byte HEX (or 12 bits) for each single LED pattern and the PIC16F1826 is an 8bit device. I attempted to compile the code with XC8 under MPLAB X IDE 3.05 to learn that the code appeared to be made for another compiler. I had to make changes to the code to fit the new pin arrangements and it compiled. I ran the MCU but at this point, the three multiplexers are working but there is no output. Is there a more correct way to drive the ten LED's/row? I haven't been able to find a different way to drive the LED's in this fashion. I am not a programming expert and am sure I'm missing the point somewhere and I have an inclination that I may be going about this the wrong way. I have the schematic and the code I've been trying to work on if requested. Any help would be greatly appreciated.
