Once the large order of LED's and 26K22 and 1826 come in, I will build the physical prototype and test it. I am learning more about the proteus software. It is a great piece of software and I am examining the MickroC software to learn more. The 46K22 can easily turn into an extensive fine test equipment albeit the project was a simple panel display. I can opt for the 46K22 version a little later once 26K22 is completed. I will post back on it's progress.
On one thought though, the physical input circuit that feeds the ADC will have to be designed with over voltage protection in mind, 300 and 600 VDC is incredibly high, but nothing is impossible. In most cases, the input is paralleled with a zener diode of a particular range (usually 5 VDC) to divert the signal to ground to avoid damaging the PIC input but also designed to signal an alert LED to tell the user that the voltage being read is too high or the software will cause all LED's to flash as a warning to the user of over range. I thank you greatly for your hard work and help in this matter.
