I was playing in spice trying to come up with a way to turn a shunt regulator into a current source as well and I came up with this
Can someone explain to me what is going on in this circuit? I kind of discovered it by accident but it seems to work great.
The problem is I would need a 600v PNP transistor as well because the supply will be bipolar and 600v pnp transistors don't really exist.
I tried to do this
The problem is the bottom limit of the voltage is cut in half.
Is there a solution to my problem?
I tried to do this
