Constant Current Constant Voltage Battery Charger
Arcan3
Joined Nov 19, 2024
28
My name is Aiman. My focus research area is on Battery chargers. I would like to know the part for Constant Current charging. As i have done a sample circuit for the CC-CV battery charger system.
I have conducted a few testing and simulation for the circuit but did not achieve CC-CV profile in the simulation. I am going to charge a 3.7V 3A 5000mAh battery. The charging mechanism should be CC then CV during the end of the charging. I'm using LM317 component to achieve constant current source circuit. TL431A acts a temperature compensated variable or adjustable Zener diode.
The input voltage is 12V and my consent is for constant current at 3A, can anyone share with me how to make it constant at 3A.
I am very happy if you can share with me tips or fundamentals for Constant Current Charging/battery charger.
ericgibbs
Joined Jan 29, 2010
21,654
hi Arc3,
Look through the application section of these two PDF's, one is for the 78xx series, which may help.
Are you using LTSpice just for drawing the circuits or actually simulating?
Your post circuit has no Common Node.
Please post your asc file.
E
ericgibbs
Joined Jan 29, 2010
21,654
hi Arc,
This is your circuit modified driving a 3.7V Li-ion cell from a 50% state of charge. SOC = .5
Needs a design improvement.
Battery current in Blue
E
Arcan3
Joined Nov 19, 2024
28
hi eric,
Thank you for the modified circuit. Can you provide me the component library that you use for your circuit as I want to try simulate it as well. thanks in advance
ronsimpson
Joined Oct 7, 2019
4,908
Vin is 12V, Vout is 3V, the difference is 9V at 3A is 27 watts. Where are you going to dump the power?
I think a switching power supply would do the job with 1W of power loss.
I can't remember how to add current limiting to this. Or just the LM2576 which limits at about 3A.
38,952
Sorry, but i am having problem running the circuit
It wouldn't do much good as that is not an operating circuit that will do what you want.
Look at my posted circuit to see what you need to change.
What is the purpose of U2 and Q2 as there connection makes no sense?
Arcan3
Joined Nov 19, 2024
28
hi crutschow,
Thank you for replying. I see that you are using LT1084 instead of LM137 right. Can i ask the purpose of using this component instead of the LM137?
ericgibbs
Joined Jan 29, 2010
21,654
Hi Arc,
You need these .include on your circuit diagram.
E
Update:
The sub, lib, mod files should be placed in the LTSpice lib folder, this shows my Path.
C:\Users\ericg\Documents\LTspiceXVII\lib
Arcan3
Joined Nov 19, 2024
28
The LM317 is only good to about 1.5A and you said you wanted 3A.
The LT1084 can go to 5A.
Hi Crutschow,
thanks for helping me with the modified circuit recently. I want to ask the options i have if i want to upscale my circuit to charge 12V battery with 1-3A current. Do i need to replace any component or do i have to change the value of my resistors. Also i could not find any LT1084 in my place hence, what are the other option can i replace the component with?
Arcan3
Joined Nov 19, 2024
28
Hi Crutschow,
I change the LT1084 to LM338 as a replacement. I intended to charge 12V battery with 1A current. Why does the voltage drop massively from 12V supply to 3V on the output?
