Connecting 12V Inductive Sensor to Raspberry Pi 3B+
SeattleThomas
Joined Mar 4, 2020
5
I am not too strong with building electrical circuits so I am just wondering if I could get some feedback on the circuit I built. I am trying to connect a 12V inductive sensor to a Raspberry Pi 3B+ 3.3V port. The inductive sensor is being used to detect a metal sleeve inside of a valve.
Below is the circuit I made on a cad program as well as the actual electrical circuit that I built on a breadboard (Pi and Sensor not included in picture). The optoisolator being used is a PS2502.
Thank you for help in advance!
bertus
Joined Apr 5, 2008
23,023
Looking at the schematic, the C and E of the optocoupler are the wrong way around.
The E should be on ground. Th C via a resistor to the powersupply.
Bertus
bertus
Joined Apr 5, 2008
23,023
Yes, a simple explanation would be the arrow of the Emittor.
It is now counter direction of the current flow.
Bertus
SeattleThomas
Joined Mar 4, 2020
5
Bertus
Thank you! As for the circuit I built, how does that look in regards to the schematic? I have a hard time transferring from drawings to building circuits.
dl324
Joined Mar 30, 2015
18,490
The inductive sensor will be connected at the VCC, I just simplified it by adding only the voltage source into the circuit drawing.
It would have been helpful if you had mentioned that.
What is the output of this sensor? Is it binary (digital) or analog? Why do you think you need an optoisolator?
EDIT: clarified the meaning of binary.
SeattleThomas
Joined Mar 4, 2020
5
The output polarity is DC and the output type is PNP. I am using the optoisolator to make sure there is less noise in the circuit.
