Confusing datasheet
ravashravash
Joined Jan 20, 2018
6
(I attached a photo of the datasheet) I'm having a hard time understanding it, I'm new to this. I have a multiplexer that switches when I give it 7,5V, I want it to switch at 3V.
Currently VDD = 15V, VEE = -15V. Should I change it to +-5V?
BobaMosfet
Joined Jul 1, 2009
2,211
Based on the test values shown, the multiplexer may not be intended to work with 3V. Unless you can provide the IC number, your question cannot be properly evaluated and answered.
ravashravash
Joined Jan 20, 2018
6
Also, what do they mean with "input low voltage" and "input high voltage", do they mean the input voltages VDD and VEE (15V and -15V)?
ScottWang
Joined Aug 23, 2012
7,509
Do you mean that when the input signal from 7.5V drop to 3V and the switch enable(INH) is on and the input 3V will be output to output pin?
The CD4051 can't check how much voltage in the input pin, if you want to do that then you need to add a comparator as LM393, LM339 or and op amp LM358 to do the voltage comparing job for the input pin and when the input voltage drop to 3V and the output of comparator will send a low to INH to enable the output function.
How is the 7.5V?
Is that a sine wave 7.5Vpp as +3.75V and -3.75V or 15Vpp as +7.5V and -7.5V?
For 7.5Vpp then you will need ±5V power, For 15Vpp then you will need ±9V or ±10V power
ravashravash
Joined Jan 20, 2018
6
It's not a sine wave. I'm bad at explaining but the input voltage is +-15V. Then I give the MUX, for example, 5V. The MUX has 3 digital input, and depending on which ones are connected to ground and which ones I "feed" a voltage to there will be a output voltage of 5V, however the output voltage doesn't show unless I "feed" the MUX with 7,5V, and we need it to appear when we give it 3V.
38,952
The cd4051be maximum total supply voltage (V+ to V-) is 20V so it can't be safely connected to ±15V.
What is the maximum plus and minus signal voltage?
That would be the supply voltages you need.
ravashravash
Joined Jan 20, 2018
6
I might've used the wrong name for the +-15 voltage.
(See attached photo)
Vdd=15V
Vee=-15V
A, B, C is digital inputs.
Then there's 5V (for example) in one of the channels from 1-7 depending in which of the digital inputs I use.
I have to give the digital input at least 7,5V (I want it to be 3V) for it to show the 5V in the output.
Sorry for the confusion.
ScottWang
Joined Aug 23, 2012
7,509
The Vmax power of CD4051 that you can apply it as 0~20V or ±10V for the +Vdd and -Vee(see the first page).
When the input was not the sine wave which only the voltage from 0V to Vmax 10V, so you don't need the power for -Vee, for the normal application then you just connected -Vee to Gnd and apply the power +5V, there is no needs the -Vee.
If you apply the +Vdd and -Vee with +5V then the digital input needs to apply at least +4.5V(see page 15), but if you apply the +Vdd and -Vee with ±5V then the digital input maybe can be apply only +3V and the INH is the same.
