CMOS Two stage amplifier design for differential modulated signal.
Alex_Khan
Joined May 27, 2020
60
Hello everyone,
I am designing LPF based differential demodulator(LPF_DDM) to retrieve differentially modulated signals, which are on-chip capacitive isolated [shown]. LPF_DDM includes a differential amplifier, LPF, and Schmitt trigger. I designed a two-stage opamp [specification below], as a differential amplifier. Simulation results of the 2-stage opamp matched with desired specifications (GBW, Phase margin, gain, etc ). However when the differential modulated signals are given as input, then opamp does not work.
Is my 2-stage opamp design and/or design parameters adequate for differential modulated input signal?
Thanks.
Design Parameters:
Input common mode range: ICMRmax = 4V; ICMRmin = 1.5V ; Load capacitance =2pF ; Gain = 1000/60db ; Slew-rate (SR) = 20v/usec. GBW=30MHz
Phase margin (PM)>= 60-degree
LowQCab
Joined Nov 6, 2012
5,102
This may not be my "thing",
I've never heard of this type of "Modulation".
What is the purpose of it ?
Why are you trying to make your own Op-Amp ?
Is this a Classroom assignment ?
