Hi guys,
I need some help with my project.
Basically, to start off with I need to design a circuit capable of detecting alpha and beta particles from a prime detector.
The signal would then be amplified where the charge coupled amplifier would be used to turn the electrical charge to a voltage output with the shaping amplifier used to change the waveform of the signal for processing.
The discriminator would be used to seperate the alpha signal from the beta signal due to the fact that alpha particles are more energetic whereas beta particles have half the charge.
Below is a diagram illustrating what I just described.
I'm not sure where to start designing the circuit and what components that I need to use.
Any help would be greatly appreciated.
Thanks in advanced.
Thanks in advanced.
