Hello, I am building a hand crank generator from a DC motor to charge a lithium battery, which will provide power to a USB port that can be used to charge a phone (slow and inefficient I know). I am going to have a series of gears so that I can spin the DC motor fast enough.
The lithium batteries are typically 3.6 to 3.7 volts.
I am a bit confused on what rout to take for the DC motor. I am looking at those mini brushless and brushed DC motors - they come in all kinds of voltages: 3.3V, 5V, 9V, 12V, etc. They also come in different RPMs, ranging from 2,000RPM to 10,000RPM. I am assuming that I will need to spin the motor at the rated RPM in order to roughly output the rated voltage - half the RPM for roughly half the voltage, etc.
Here are my main questions:
I know that I need to regulate voltage to 5.0V for the USB port and 3.7ish volts for the lithium batteries. Is it going to be better to use the 3.3v version motor and boost this voltage up to the 3.7ish volts for the lithium batteries (I will use a battery management charging circuit for this), and then further boost the voltage up to 5.0V for the USB port? Or is it better to use for example the 12V version of the motor, and buck the voltage down to the 3.7ish volts for the lithium batteries?
Is it possible to do this so the faster and harder you turn the crank, the faster the lithium batteries charge? It seems like once you are turning the crank, and you exceed the 3.7V, that anything above that is basically wasted? I am a bit confused here.
Thanks and any help or advice is greatly appreciated!
EDIT:
For the sake of this discussion not getting offtopic, Lets ignore the phone charging, and lets just say I want the 5.0V USB port for charging a small USB thumbdrive style flashlight. Low power requirements.
EDIT:
