Circuit Analysis
uppi_777
Joined Feb 26, 2018
70
Could someone explain me about the circuit given below
May i know how does this Circuit functions and the application
Looking forward for your inputs
Thanks
dl324
Joined Mar 30, 2015
18,328
Is this school work?
Is the source AC or DC? What does the green squiggle connect to? Does the black arrow represent ground?
uppi_777
Joined Feb 26, 2018
70
Thanks
Source AC
green squiggle is Earth cable connection
Black arrow represents Discharge tip
22,082
Repeating yourself is not helpful and many people consider it rude. I told you in post #3 how the circuit works, but you were obviously in such a hurry that you blew right past my explanation. In any case here it is again.
The long winded explanation:
  1. When the switch is open the high voltage source charges the capacitor up to but not exactly equal to the voltage of the source. The voltage on the capacitor approaches the value of the source asymptotically. If the voltage is high enough there may be some corona or leakage (arcing).
  2. When the switch is closed and the tip is at a lower potential than the voltage on the capacitor, the capacitor discharges through the resistor and asymptotically approaches zero volts, but it never actually gets there.
  3. Since the discharge resistor is several orders of magnitude smaller than the charging resistor, the capacitor will charge very slowly, and discharge rapidly.
What more do you want to know?
dcbingaman
Joined Jun 30, 2021
1,065
May i know how does this circuit function??
If this represents a HBM (Human Body Model). The KV source is the human body. The 50Mhom resistor represents the human body ability to charge to high voltages via ES build up. The capacitor represents that amount of charged held by the human body. The switch when closed represents an ESD event. Basically, an ESD event is a large discharge from a high voltage capacitor, the capacitor itself representing the human body.
22,082
Cap isn't going to have much charge with an AC source. It'll be constantly charging and discharging.
If the switch does close it will short the AC source. Good luck with that if is connected to the generators at Hoover dam. If it does represent the HBM, then the discharge current is relatively insignificant and 5 RC time constants is like 250 ns.
BobTPH
Joined Jun 5, 2013
11,515
If the source is AC, it is a low pass filter with, basically, a short to ground switched in.
I think that is highly unlikely.
Does anyone else wonder what the rest of the picture shows? Clearly it has been cropped.
Bob
22,082
Bob
I guess somebody must think it would be a distraction.
