circuit analysis basics
WBahn
Joined Mar 31, 2012
33,282
What is the current flowing (and in what direction) in the bottom wire immediately below the current source?
If you have studied current dividers, that should be enough of a hint.
If not, then can you see how to combine the two left-hand resistors into a single effective resistance and use the answer to my earlier question to determine the voltage across both of them?
