Hey sorry, but I must have not seen this, but I live in New Glasgow, Nova Scotia; that is in Canada...
Try retro-reflecting tape or a bicycle reflector mounted with double stick foam tape.Using a retroreflector on on side will allow the electronics to be all on the other side.
Because my boss "my female cousin" wants to try if I can get them to work; she might be thinking of bringing the foul line back, why, I do not know that because most bowling centers in Nova Scotia do not use them any more. And that fact that if they where back a lot of the older bowlers would be a hassle because a lot of them do step over the foul lines; that's because I have observed a lot of bowlers don't care anymore.More complicated but maybe more reliable would be modulated IR. Why reinstall the foul line detector ?
Only thing left of foul det. in my bowling lanes is the reflectors.
Yes I do have a wealth of parts from Allied electronics, Mouser, and Digi-key.Can you get + 5V power to the circuits ? Do you have a source for parts ?
Do you want to try for a modulated IR system ? I noted that my lanes were well illuminated with a complete line of fluorescent lights near the start line.. How wide are the lanes ?
I'm tied up until late next week
That is something that I do not get to do, and not to sure what it really means; although I consider my self 100 percent openly gay, the town that I live in is not; and a lot of guys here are still in the closet..Bernard said: I'm tied up until late next week.
Bernard, are you into BDSM?
yes.I tried to recreate the beam break from post " Help with simple beam switch " by deuce01, but not a peep from Rx. Simple seems to have fallen to the wayside. Might next try a module like OPL561-OC with single modulation.- If you are still interested.
That is odd. I thought I had used bicycle reflectors in the past. All I can think is that the plastic in the reflector does not pass IR very well. If that is the case then white retro-reflecting tape would be my choice.A red multi faceted reflector was tried with boor results, but a piece of shiny beer can worked as a first surface mirror for testing.View attachment 149761
I was able to remove the old blue painted covers; that used to house the old foul line and the signal and power line were removed; but I can run some new ones down under the ball return since there is lots of spacing under the gutter side.Maybe this will work. With similar parts detection was reliable at 10 ft. Tx IR LED is no part number, CAT #
ILED-13 from All Electronics, 940 nm, 60 ma continuous, 1A pk., 5 mm., 16 deg. From Digi-Key a match to
OPL550-OCA is SFH4545, 10 deg. or TSAL6100 but are not 5 mm packages.The mounting is as shown in post by ducey01. I found a shorter focal length plastic tens at Ace Hardware 3 cm dia., 5 mm fl. but not tried yet. At 5 v, buzzer might not be loud enough but rower availability has not ben established.
NO the all of the old stuff has been removed on both sides...That is odd. I thought I had used bicycle reflectors in the past. All I can think is that the plastic in the reflector does not pass IR very well. If that is the case then white retro-reflecting tape would be my choice.
I keep meaning to ask if a reflector is still in place, leftover from the original foul line detector.
p.s. My first surface mirrors of choice are hard drive platters.![]()
