cd4017 how to prevent reboot
sghioto
Joined Dec 31, 2017
8,751
That's the way it works, each output stays high until the next clock signal.
There is a work around. What are the outputs connected to?
sghioto
Joined Dec 31, 2017
8,751
How do you know what the count is if all outputs connect to one LED?
So you want that LED to stay on for only a short time before the next clock signal?
Petrichor
Joined Dec 19, 2024
36
Yes, that's exactly what I want. I want the led to flash every time I press the button.
Petrichor
Joined Dec 19, 2024
36
How long of a flash?
This is not very important. Actually, I won't be controlling an LED, the outputs will be connected to the signal pin of a relay. I didn't say this to avoid confusion. It is enough for the relay to detect the signal every time I press it.
Petrichor
Joined Dec 19, 2024
36
When you get to the eighth button press should the LED stay lit and not flash?
I actually fixed this. But let me tell you anyway: it doesn't matter in either case. The only problem for me is that when I press the button the relay does not have time to turn off and on. Because it switches from high to high every time and remains in the open position all the time.
sghioto
Joined Dec 31, 2017
8,751
What is fixed the relay problem?
Petrichor
Joined Dec 19, 2024
36
I cannot imagine any use of a relay where it does not matter how long it is activated.
I guess you're a little nervous? If active time was important I would know it. You can only answer if you know the answer to my question. Let me help you think a little bit though. Since the output of the relay is connected to 555, it does not matter how long the relay remains active. I can adjust this from 555.
BobTPH
Joined Jun 5, 2013
11,659
If you using the signal trigger a 555, no relay is needed. And we would be giving you completely different advice if we knew that. Keeping back information can only get you worse answers.
And, the time of a pulse to a relay always matters. If you don’t believe me, try activating a relay with a 1 usec pulse.
I am beginning to feel like a dentist.
Petrichor
Joined Dec 19, 2024
36
This is a project assignment and I was asked to use a relay. but I guess I decided to use the relay elsewhere. This challenges me. Even if the CD4017 is not connected to any battery, it detects this when I connect its output pin to 555. What kind of connection do I need to make to trigger directly with CD4017?
Petrichor
Joined Dec 19, 2024
36
Somehow I managed to send signal directly from cd4017 to 555. But I still need the time difference between passes. For example, when I connect a single LED to q1 and q3 (via a diode), I can get two signals. However, when I connect it to q1 and q2, I can only receive a signal from q1. When I switch to q2 it doesn't detect it as a different signal. Because I change from high to high. Does anyone have any ideas to solve this problem? I tried to solve it with a capacitor but I failed. Maybe you know a solution.
Petrichor
Joined Dec 19, 2024
36
I am using CD4017 and 555 IC. Every time I press the next button, a signal is sent to the 555 by the CD4017 and the LED turns on for a while (theoretically). But there is a problem. Since I go from high to high without dead time when I press the button, the 555 does not perceive this as a different signal. That's why the 555's trigger remains active all the time. Is there any way to solve this? And do you see any problematic connections or redundant connections in the circuit?
