[SOLVED] CD4017 reset issue
Sebbi
Joined Mar 24, 2024
15
I have a circuit build with an CD4017 which gets a clock signal from a CD4047.
On the CD4017 I connected 4 LEDs behind an ULN2004AD transistor array.
I want the 4 LEDs blink in sequence which works good so far.
The LEDs are connected to CD4017 Q0-Q3 (pins (3, 2, 4, 7), Q4 (pin 10) is connected to RESET (pin 15).
So I want the 4 LEDs to blink and then reset the 4017 and start with Q0 again.
As I said that works quite well BUT the CD4017 is not reset on Q4. There are a few (milli-)seconds black where none of the LEDs is lighting up and then it starts back with Q0. In the "blackout time" the 4017 runs through the ports Q4-Q9 where no LEDs are connected. But I want it to reset on Q4. I don't understand why its not working?
Hope someone can help. I already checked so many topics here (and also on Google) but none of the solutions worked for me...
Thank you.
Circuit diagram (made with easyEDA):
Voltage is +3.7V, not 5V like on the image.
dl324
Joined Mar 30, 2015
18,481
What current are the LEDs being operated at?
That's a terrible way to draw a schematic. I refer to that style as "netlist style" because it's about as difficult to read as a netlist. Pin order symbols are only useful for showing routing congestion. They do nothing to convey circuit intent.
Will take some time to analyze your "schematic" to make sense of it before I can comment on your problem.
35,247
The symptom you describe suggests that RESET is not connected to Q4. Check your wiring.
Check using other outputs.
Sebbi
Joined Mar 24, 2024
15
I already tried (all) other outputs but with no effect.
If I manually connect pin 15 to VDD the CD4017 resets but it doesn'r reset when it's triggered over one of the CD4017 outputs.
I have another CD4017 on my board which has the exact same wiring and this one works well.
I already tried another PCB with another CD4017 to see if the chip is broken but I have the same issue on the other board.
The only difference is the clock, the CD4017 which works well gets it's clock from CD4047 pin 10 and the other CD4017 which doesnt work as expected get it's signal from CD4047 pin 13. The reason is that I need the different impulses (pin 13 is double "speed" than pin 10).
dl324
Joined Mar 30, 2015
18,481
Have you tried swapping CD4017?
Post a picture of your wiring. Sounds like a wiring issue or defective counter.
Sebbi
Joined Mar 24, 2024
15
Yes, I tried that already. No effect.
I could post a photo of my PCB but wou wouldn't see anything there because I ordered the board from JLCPCB so most of the wiring is not visible. I also soldered another PCB with completely new parts and it's also not working. So I think the CD4017 is okay, it must be somewhere else.
Sebbi
Joined Mar 24, 2024
15
You have two outputs shorted together. (CD4047 output pin 13 and CD4017 pin 10).
Use an OR gate or diodes to separate them.
Sorry but I don't see where there are shorted together?
CD4047 pin 13 goes to CD4017 pin 15 (clock)
CD4017 pin 10 (Q4) goes to CD4017 pin 15 (reset)
Am I missing something?
dl324
Joined Mar 30, 2015
18,481
There's no short. It's just difficult to follow your schematic "style".
Your usage of connector symbols is also non-standard. The ones that point towards the pins are typically inputs and outputs would use a connector that pointed away from the pins.
Sebbi
Joined Mar 24, 2024
15
I'm sorry if this confuses you. The use of the symbols is predefined in easyEDA and unfortunately cannot be changed by me.
dl324
Joined Mar 30, 2015
18,481
It doesn't confuse me. It just makes your schematic more difficult to read and my preference is to just not read them. Yours was simple enough that I decided to try to help.
Crappy tool...
Pin order symbols are almost always bad. The CD4047 timer symbol in Eagle isn't as good as it could be, but it's far better than what easyEDA is using. Those symbols have absolutely no thought given to them.
Sebbi
Joined Mar 24, 2024
15
Crappy tool...
Thank you very much, I really appreciate your help. I'm also getting a bit frustrated about what else I can do.
dl324
Joined Mar 30, 2015
18,481
Do you have a dual channel oscilloscope or logic probe that you can use to monitor the signal on O4?
Two channel scope because you want to trigger on the clock pulse to be able to see any brief HIGH output on Q4.
Sebbi
Joined Mar 24, 2024
15
Sorry I don't have any of those devices. I just have a multimeter.
Sebbi
Joined Mar 24, 2024
15
Try testing the circuit first on a breadboard.
I put everything on a breadboard yesterday and tested and everything works perfectly.
On the one hand, this is good because it means that the circuit basically works. On the other hand, bad because the problem still exists.
