Johnfoxwell
- Joined May 23, 2021
- 18
Always taught never to have pull-down resistors. Recipe for noise problems.
Sure...I need to clean it up a little...then I'll post..That's a very useful model.
If you could post the model and symbol files, I'd appreciate it.
Certainly that is possible in ANALOG systems, and in poorly laid out/assembled digital systems. Properly connected pull-down resistors have never been a problem for me, except when I used too high a value of the resistor. I learned from that.Always taught never to have pull-down resistors. Recipe for noise problems.
The time-constant in my circuit is 470ms.(the time constant you chose is 220 sec!)
Which clock input?so the clock input amplifies the slow input
Per your request. Here is switch with bounce model.That's a very useful model.
Interesting.For CMOS inputs without Schmidt triggers, a slow input with not trigger on either edge as stated several times here. What happens, because CMOS logic are push/pull devices (the "complementary" part) and their gain is low for the older CD series, so the clock input amplifies the slow input (the time constant you chose is 220 sec!) (also the inputs have some capacitance), as the slow input rises, the output of the logic level clock input can switch MULTIPLE times on a single slow edge which can toggle the output several times! Check it using a fast scope input. Also, when this happens, you many need a bulk (bigger) power bypass capacitor, since the slow rising input's N and P channel MOSFETs can short out the power supply, which can also add bounce. I played with these back in 1975 where I used "real" RCA chips (RCA was the creator of CD series CMOS). Look at the chip's schematic from an old datasheet that literally shows the raw internal circuit. Most datasheets now only show a logical equivalent which is worthless for this kind of analysis. Even if you got your knowledge from college, they really don't go into the details of this, which some would say is a lost art, but it's worse, it's neglect.
