Capacitors on plug?
bidwin
Joined Jan 22, 2015
14
Mr. Know-nothing here again. Long time no post. I removed an IEC socket from an old computer and plan to put it in a case that will hold my power supply, chargers, and batteries used with my radio control planes. The socket has a metal bracket bracket that's connected to the ground lug, and it has what appears to be CS221K capacitors between ground and the hot and neutral lugs. See picture. Why are the capacitors there? Seems like they'd short the plug. Are the capacitors directional? Would it hurt to leave them when I put the socket in my charger case?
Thanks,
Charlie
bidwin
Joined Jan 22, 2015
14
Thanks for the response, Jony. The links were very helpful, especially the second one. I don't think I need EMI filtering for my needs. I don't see any with my power supply now, unless it's internal, and I don't want to mess with a potentially live element on my case should a capacitor short.
Regards,
Charlie
bidwin
Joined Jan 22, 2015
14
KISS,
Your link is the same one Jony130 sent me. If I recall correctly that link stated the caps were type Y, and if a short were to occur that could create a potentially dangerous shock condition. The link implied the risk was small but didn't say it couldn't occur.
OK. The caps do two things:
They prevent RFI from getting in and prevent RFI from getting out. They also reduce spikes that can damage the equipment.
I, personally have never seen one fail.
If you use a plastic case, your totally good. Double insulated as they say.
I'd really would leave them in.
To give you a better idea what a "real filter is", see http://www.te.com/usa-en/product-6609060-6.html
Some surge suppressor power strips contain comprehensive filters. e.g. Isobar. One of my favorites.
