Can someone help identify this part
easygoin4
Joined Feb 16, 2019
Also there is a tiny diode below the yellow part, I need to know a part number for this.
As you see I replaced the other larger diode but it was a guess
dl324
Joined Mar 30, 2015
18,465
Welcome to AAC!
It’s yellow like a resistor
Numbers on it
BK4
9741
The arrow is confusing. It looks to me like it's pointing at the encapsulation material.
Is this the yellow resistor-like component you're talking about?
If so, it's a ceramic cap. The value must be marked on the side that you can't see because the info you posted is meaningless.
dl324
Joined Mar 30, 2015
18,465
The diode below the cap could be a zener or signal diode. Is the diode above the capacitor in the same package as the one you replaced?
Most through hole diodes have the part number printed on the package.
eetech00
Joined Jun 8, 2013
4,724
Welcome to AAC!
The yellow thing looks to me like an RN60 type resistor...
easygoin4
Joined Feb 16, 2019
Thanks everyone, I have no idea about these parts, see it’s a circuit for an older ATV which is not available or a diagram available.
The larger diode I replaced was burnt up and it was a guess, I have 3 other boards with some parts I have identified.
I just found out the smaller diode was broken in half with a magnifying glass.
I will remove the yellow thing and see if find more numbers
easygoin4
Joined Feb 16, 2019
It looks just like a RN60 resistor as you mentioned, however there are no more numbers in mine, but did get numbers off another one
9809
KL4
This is a 12v circuit that controls a temp light and a electric fan.
The thermistor in the oil cooler sends signal to turn fan on when resistance in low enough, then the light comes on if gets too hot or lower resistance.
I believe it’s a circuit using Ground to complete circuit like on boats.
28,269
That yellow thing with the rounded ends looks a lot more like a capacitor than a resistor, especially since all of the resistors look quite different from that item. Possibly a tantalum capacitor.
