Thank you very much Soeren!Just changed it to 2.5s in and 12.8s out, by adding back a single resistor.
However, the attached .pdf won't reflect that, but I'll update it tomorrow. Apart from what's in the .pdf, you'll need a 22k resistor:
http://www.gmelectronic.com/ru-22k-0207-0-25w-5-p119-066
The exact position of the magnets, relative to the switch, depends on the strength of the respective magnetic fields, but the reed won't need to be smack dab in the middle.
Different strength magnets can be used and while I have to work the thought a bit, either the lid-magnet can close toward a bit of iron or another magnet, which may then be usable for bias as well... I need to think it through.
If you want to use magnets for closing, the one I linked from GM (AlNiCo magnet) won't do, they're much too weak. They do have a set of 10 magnets from Velleman but the latter describes them as "rating: N35~N45", which is sort of nonsense, as the Nnn describes a set of parameters of a magnet (like strength and high temperature limit) and they don't have such loose specs.
Besides, although neodymium magnets are strong compared to AlNiCo, N35 is about as weak as they come,while N45 is about "medium" - really strong neo's are N5n.
They'd all be OK for your box though, but they're eur 5.07 for 10 at GM, so if you have a cheap thrift store locally, you might be able to pick up a few magnets with attached fridge ugliness much cheaper, or perhaps one of the weighted steel wires, that uses small neo's for attaching postcards and photos to the wire - the ones I've seen had 8..10 magnets in such a "set" - just make sure that you get the strong neodymium types (if they look small for the purpose, they probably are neo's) - there's and endless amount of cheap stuff and toys using them.
The reason to go for neo's is to get the dimension down while keeping a good strength - if you stand a cylindrical magnet on the edge on eg. a table and tip the table a little, a strong magnet will try to only roll a path of east-west (if polarized along its length, i.e. N-S on the plane sides) - that's how strong they are.
I didn't put wire on the list, as you'll likely be able to scoop some up - even a short piece of CAT5 "Ethernet" cable will give you plenty.
The sponge I left out as well, no extreme need for it, as you can use a moist tissue paper or a moist piece of cotton cloth. The sponges are made of cellulose (organic) and must be moist in use, or they won't last long - I use distilled water on them, to make them live longer and stay softer - they're pretty stiff when dry, no matter the water.
By moist I don't mean wet - the moisture only has the purpose of protecting the sponge by a ~100°C vapor barrier. If wet, they'll cool the tip (and shock it a bit) - not good.
You can get cellulose sponges made for several other purposes. Some (most?) sponges for wiping a black board is that type and the cheapest I've found are some oval shaped 1,0..1,5cm thick sponges used for cleaning kitchen and bath - just read on the packet what it's made from. They're a light yellow-beige-ish color.
A plastic foam sponge would die screaming and hurt your soldering tip as well.
BTW. do you shop in GM's physical shop or order online?
Here's the .pdf View attachment 84848
The timing sounds great!
And the PDF is outstanding! I understand everything well and the schematics are so well made, thank you so much!
I have just two questions:
Concerning the parts, do they have + and - side or are the two wires identical? I can see there are some + signs every now and then and I am not sure if it has something to do with the positive and negative poles (I am thinking that they are just CAD symbols). I know that LEDs have + and - and that one is longer and other shorter, but I am not sure if it is the same with the resistors and capacitors for example and if I can find in the schematics on how to connect them in this way.
And the numbers above the schematic and the letters on the side, what do they mean please?
"Regretfully, I did not get around to show how the reed switch and the LEDs should be wired, but maybe tomorrow." Please, if I may ask you for this, it would help a great deal!
I ordered all the parts online and I will be picking them up in the physical shop. I checked if they are all availible in the physical shop in my town (Prague) and they were all there, except for the capacitors. I checked the alternatives and the closest capacitors availible were these, so I took them instead: http://www.gme.cz/cea-470u-25v-vis-asm-10x18-p002-096
They are pretty much the same, except these are made for 25 V (and I guess they will be slightly bigger) - I hope it is not a problem.
Don't worry about the closing of the lid with the reed magnets. I was just thinking if it would work that way, but I can easily buy two neodymium magnets (I ordered 4 of these just to be sure - might use the other two for the reed switch as well http://unimagnet.cz/154-KT-03-01-N.html and 2 of these (these might be better for the switch?) http://unimagnet.cz/758-KT-01-01-N.html) and place them in a different part of the box solely for the purpose of closing the box.
I bought a thin, single core wire from the GME shop. I didn't went for the sponge and the solderless testing board though, I hope I haven't made a mistake. I will use the tissue papers for cleaning the tip.
I will also buy the solder "gun" today.
So everything will be prepared soon! I will go to a workshop tomorrow to finish and make the wood+plexiglass part of the box. I will make the box 10 cm in lenght, 5,5 cm wide and 4 cm deep. I hope it will be enough to fit all the things in there (including the the gift itself ).
And I will have the time to prepare the electronic part ideally in friday or during the weekend. Oh boy, I am so excited and nervous at the same time! It is like if I would have some exams ahead.. :-D There are so much things to do apart from the electronics project. I think my head will explode :-D
Thank you so much again for helping me out with this Soeren, I don't know what I would do without you!
