Not to be too disappointing, but reeds aren't exactly challenging, as long as you don't manhandle them and always bend their pins with a pair of pliers between the glass tube and the bend (with a bit of the pin/wire between the pliers and the glass tube), as the tube is fragile and will break if you try to bend them holding the tube.The the magnetic switch is even better! I can imagine it must be more difficult to handle, but I love a challenge.![]()
I'll recommend reading what Meder have to say about it (and then chill a bit afterward, it's not as hard as you might think after reading their article).
http://www.meder.com/precautions4.html#c8183
When you've read that, air your concerns if any and we'll take it from there.
Yeah, I hear you - it takes interest to learn! Back in middle school, I only really excelled in science class, art class and English (as a foreign language), in almost all other classes I was always getting notes for my parents, that I wasn't focused and just sat staring out the window.And you are right, what I wouldn't do for the princess of my heart :-D I am already learning things I would never imagine to learn ever in my life. Things I even quite disliked back in school (physics)![]()
Even math was boring then and these days, I regularly handles math that my different teachers would have given up on
You gotta see a need for it or just be adequately curious, then you'll learn more and learn faster.
Yes, you are correct.[...] The only thing which is not clear is how a transistor works, how do I use it and to be more specific, which one to use. I already know how to calculate resistors, but I have no idea how to calculate a transistor. I understand that I need a transistor in order to transform a lower current into a higher one, powering those 3 LEDs connected in parallel, am I correct?
The transistor isn't one you'll learn completely in a day or two, as it can be used in many configurations and there's lots of parameters to it, but for your specific purpose (which you should stick to for now), you could imagine it as a valve that can be turned easily and let a huge pressure through.
A small current through the base-emitter part will open for a current of 100 to 800 times that through the collector-emitter part with a BC547 (depending on the suffix, A, B or C, where C has the highest current gain).
The BC547B is the most used all-round small signal transistor in Europe. Giorgos specifies a BC548, which is almost the same, although specified to 30V max, where the BC547 can handle up to 50V (and BC546 goes up to 80V). At 6V any of them will do.
When no suffix is used, it's common to go with suffix B (which most transistor without suffix marking really are).
I think BTW. that you should keep to the simple version for starters, this is not about making a killer circuit and I'm sure that your princess will be joyed, whether it's perfect or have a slight delay - she'll appreciate it (and you) for the time you took making it and learning how to make it
If you get the base version working in a short time, you could consider the slightly more involved version (you might wanna get all the components in one go though).
I'm not sure why Giorgos selected the transistors he did, perhaps it was just what he had at the time he made it, but for Q2 (in the extended circuit), I'd use a BC557 (the PNP version of BC547) and perhaps a BC337 (the NPN version of BC327), as it's a driver, able to handle 6 times the current of a BC547.
I check'd (almost no pun intended, doesn't really work in writing
http://www.gmelectronic.com/bipolar-transistor-bc557c-to92-p210-039
http://www.gmelectronic.com/bipolar-transistor-bc337-40-to92-p210-019
They're both the highest gain binning and for strange reasons a bit cheaper than the more moderate gain types.
Get a couple of each, if your budget allow, then it's not catastrophic if you burn one and they'll be good for little experiments too.
As mentioned, there's several parameters to know, to select something that works. Current gain is important in your project and so is max. current, but if you just go with what I suggested, you're in the green and you can learn a bit at a time on transistors - to give you an idea of how complex it is, I know a guy who took his final engineering exam by discussing a single small signal transistor with all it's parameters (and he passed with flying colors).As you told me that the voltage rating is more about how much the part can handle and not to which kind of current it is assigned to, I am guessing that it is the same with transistor? Maybe the only thing I need to choose correctly and specificaly here are the resistors at this point?
The one I linked to is from GM too and it's better and only a third the price. The reason that the one you found is expensive is the size, it's one of the smallest reeds available at only 5mm (it's the length of the glass tube itself), while the one I linked is 14mm.If you please could give me any guidance, I would really appreciate it so much! And especially with the reed switch solution. I found the local shop have lower voltage ones too, but they are much more expensive: http://www.gmelectronic.com/reed-magnetic-sensor-ka-80-p634-530 However, they have all kinds and they are all in stock, so I can get them quite easily.
While I have a specific project for 5mm reeds (or smaller if I can find them), they're a wee bit fiddly to handle due to their small size, so you really should go with the 14mm - they have 5 times the current rating as well and you have plenty of room for the 14mm version (which is only 2.2mm in diameter).
I'll take a hard look at the schematic tomorrow and if I change anything, I'll draw you a new one. I assume you will solder it up on a matrix board like this(?):
http://www.gmelectronic.com/universal-joint-160x100-rm-2-54-belt-joints-p661-048
And if so, I'll make you a layout and base it on components from GM.
I can post some photos on the reed and how to wire it up if that would help.
For experimenting, you might consider getting one of the following two solderless breadboards:
http://www.gmelectronic.com/breadboard-zy-60-p661-137
http://www.gmelectronic.com/building-plate-for-breadboard-zy-170-w-p661-138
(or you could go for a more expensive model, GM has several sizes).
Oh, not to forget... What kind of fade in/out time do you imagine?
