It looks like something inn the filter section is leaky but not a total short. It could be either of the two 47 nF capacitors, the varistor or the common mode choke. I would mostly suspect the varistor. You will probably have to remove components one at a time until the bulbs no longer light. I suggest starting with the varistor then the two 47 nF capacitors one at a time and finally the common mode choke. (Do not replace the components after removing them. ) Before you start removing components try leaving the board powered up for about 5 or 10 minutes, Switch off at the isolator then touch the filter components to see if one of them has become warm. That may show up the faulty component.
The two 47 nF capacitors in parallel will have a reactance of about 32 K ohms at 50 hz which would pass a current of about 13 mA through the lamps but I don't think that would even make the filaments glow dull red, Check that the lamps are marked 60 W. (If you have been supplied with 15 watt lamps they may glow with a current of 13 mA.)
Les.
Les.
