I have trouble understanding what this circuit does, can anyone help me please?
Giankejo77
Joined Jan 26, 2025
6
Thank you, Eric.
I am suppose to plot the waveforms of the left side, the A,B,C nodes and the right side with D,E,F nodes with respect to time, knowing that node C oscillates between +1V and +11V and the LEDs have 1.4V turning-on voltages.
I have the major trouble with the right side, I don't understand the path of charge/discharge of the capacitor, when is the green LED or the red+yellow and how I can approach the Vout waveform.
Giankejo77
Joined Jan 26, 2025
6
Firstly I said: to turn on the LED I need 1.4V, so at node D I'll have 2.8V. Then I did the two cases when C is +11V or +1V, if the former the voltage across the 1nF cap is 11-2.8 = 8.2V is the second I'm not able to answer why it's not negative. Then I know that if node E is at 1.4V the yellow LED is on I have a current flowing equal to I = (12-1.4)/2.2k= 4.8mA. After that I wasn't able to go on
ericgibbs
Joined Jan 29, 2010
21,573
Hi G77
Have you checked the typical LED voltages?
BTW: What frequency do you calculate at Node C ?
E
Giankejo77
Joined Jan 26, 2025
6
Thank you for your answer. The text doesn't say the oscillation frequency of node C, and for the LED I know only the turn on voltage of 1.4V
ericgibbs
Joined Jan 29, 2010
21,573
hi G77,
A Yellow LED forward voltage is not 1.4V.
Where did you get the LED operating voltage values, also what do assume the RED and GREEN LED voltage values.
E
BobTPH
Joined Jun 5, 2013
11,653
First, see if you can work out how the first opamp operates.
What state is it in when power is first applied?
What is changing, and at what rate?
When does the output change?
What happens after that?
ericgibbs
Joined Jan 29, 2010
21,573
Hi G77.
If you could draw/sketch the waveforms on that original image of the circuit, the waveforms and voltages you calculate it will help us easier to follow your work.
E
Giankejo77
Joined Jan 26, 2025
6
It's an exam exercise, so this is all I know. I understood that the first opamp acts as a comparator to generate the C waveform between 1V and 11V. Answering Bob, the rate of the of change probably is the time constant of the circuit so tau= 100nF*22k, and the output change relatively to charge-discharge of the capacitor. But I'm non able to draw the waveform.
ericgibbs
Joined Jan 29, 2010
21,573
hi G,
I understand now how the LED's 1.4V, it is as stated in the question, but be aware in practice the range of colours have different forward voltages.
Sketch the waveforms, post and we can check them.
E
MrAl
Joined Jun 17, 2014
13,795
I have trouble understanding what this circuit does, can anyone help me please?View attachment 341260
It looks to me that you are going to have to analyse OA1 fully in order to find out what the frequency of oscillation is and of course that includes the pulse timing. This is going to take some careful thought on how this works due to the configuration and the given output voltages, which are all important too.
One of the reasons is that the circuit is coupled with a capacitor, and capacitors charge and discharge.
So do you know how to analyze OA1 in detail?
It's not really that hard but might be unusual for you if you've never did a lot of comparator circuits before this.
Giankejo77
Joined Jan 26, 2025
6
Thank you all for the help, I know that OA1 is a comparator and generates a signal. I was also able to draw the waveforms so thank you.
