Can anyone help me unravel the mystery of my LED circuit?
gmaffla
Joined Aug 14, 2025
He comprado desde Temu, un pequeño circuito de luces led para mi máquina de coser y me encuentro con el siguiente comportamiento extraño: Al accionar su interruptor, los led se iluminan en forma intermitente rítmica, no brusca como cuando hay contacto falso. He puenteado los terminales del interruptor y la luz se enciende fija, lo que me ha hecho suponer que dentro del interruptor hay un circuito integrado que motiva la intermitencia secuencial pero al desarmarlo no encuentro circuito sino solo las laminillas de contacto normal. He puenteado dichas laminillas y obtengo, como antes luz fija pero, aquí esta lo raro, al unir directamente las laminillas, obtengo de nueva la luz intermitente secuencial. ¿Puede alguien ayudarme a dilucidar ese "misterio" ?
Moderator edit: Google translation
I bought a small LED light circuit for my sewing machine from Temu, and I'm experiencing the following strange behavior: When I flip the switch, the LEDs flash rhythmically, not abruptly as with a false contact. I've bridged the switch terminals and the light stays on steady, which led me to assume that there's an integrated circuit inside the switch that causes the sequential flashing. However, when I take it apart, I can't find a circuit, just the normal contact pins. I've bridged these pins and, as before, I get a steady light. However, here's the strange thing: when I connect the pins directly, I get the sequential flashing light again. Can anyone help me unravel this "mystery"?
34,804
Puede alguien ayudarme a dilucidar el misterio de mi circuito led?
Este sitio web está en inglés. Escriba en inglés, por favor.
This is an English only website. Please post in English.
BobTPH
Joined Jun 5, 2013
11,513
Is there a black blob? ICs are often hidden under such a blob.
Try pressing the button repeatedly. It probably will cycle through several modes.
panic mode
Joined Oct 10, 2011
4,973
the attached ZIP file contains video of the LEDs in action. it shows cable with one wire cut. when the cut ends are connected directly, LEDs are pulsing. when they are connected by jumper wire with alligator clips, light appears to be steady on. i see same behavior on some of LED streetlights.
my guess is that LEDs are powered by an constant current driver that operates as switching regulator. newer ones seem to work at considerably high frequencies. changes in wiring can introduce noise that affect the controller which then goes into hiccup mode.
boostbuck
Joined Oct 5, 2017
1,042
Perhaps a high resistance connection via the switch contacts. This is often the cause of LEDs flashing, as the limited current inflow has to charge the driver caps before the LEDs switch on and discharge them.
Seems a new switch is needed.
gmaffla
Joined Aug 14, 2025
Gracias por sus opiniones. Les comento para lo que pueda servir, que después de varias pruebas, constaté que la causa del funcionamiento intermitente parece residir en la fuente utilizada ya que, al ensayar con otros cargadores de celular obtuve el funcionamiento normal.
