Cable tie mounts
cmartinez
Joined Jan 17, 2007
8,765
For years I've been using plastic cable tie mounts on all of my machines such as this:
And they work quite well, except that the stupid adhesive cushion that they have are terrible and extremely unreliable. They will stay attached for perhaps a year or two, but after that most of the time the adhesive becomes weak or even spontaneously falls off.
So what I do is I arm myself with patience, and then I painstakingly remove each and every idiotic cushion by hand. And then I glue them to the intended surface using polyurethane adhesive, which is far more robust and reliable.
All of that is an annoying and tedious process. Question, are there any other options out there for these things? Are there tie mounts that do not include the adhesive cushion?
@MaxHeadRoom , this sounds like it's right up your alley, any suggestions?
cmartinez
Joined Jan 17, 2007
8,765
To what surface do you attach these? I’ve used mounts with a screw or bolt instead of depending on the adhesive. Some come with both options, but by using a mechanical fastener you don’t have to depend on the adhesive.
I normally attach them to a natural, non-anodized aluminum plates. What I do is I first sand the surface a little bit using fine grain sandpaper, then thoroughly clean it with de-greaser, and finally add the adhesive. But those cushions won't work on any surface.
cmartinez
Joined Jan 17, 2007
8,765
gramps
Joined Dec 8, 2014
86
On vertical surfaces, I'll place the mount where I want it and then apply a little cyanoacrylate glue to the junction. Never had one come loose.
MisterBill2
Joined Jan 23, 2018
27,530
I have used the ones like Max shows in post#10, and some similar through hole ones. They last a very long time. Those lick-and-stick ones would seldom hold for more than a few minutes, in my experience of building control panels.
18,105
That is a very good option that I'll give some serious consideration to ... only thing that bothers me (a little) is having to drill a hole to attach them to.
Many thanks!
For what it's worth, I've seen the thru-hole ones in a lot of appliances I've torn apart. I'm not thrilled to see them because I know they stay very reliably attached and can make disassembly that much more work. They're usually attached to a bracket or something that is not impaired by a hole.
