For years I've been using plastic cable tie mounts on all of my machines such as this:
And they work quite well, except that the stupid adhesive cushion that they have are terrible and extremely unreliable. They will stay attached for perhaps a year or two, but after that most of the time the adhesive becomes weak or even spontaneously falls off.
So what I do is I arm myself with patience, and then I painstakingly remove each and every idiotic cushion by hand. And then I glue them to the intended surface using polyurethane adhesive, which is far more robust and reliable.
All of that is an annoying and tedious process. Question, are there any other options out there for these things? Are there tie mounts that do not include the adhesive cushion?
@MaxHeadRoom , this sounds like it's right up your alley, any suggestions?
