Busboard Prototype Systems Breadboard Heads Up
PICNewbee
Joined Mar 31, 2017
355
I just put a 16F886 in a new 830 hole BPS breadboard.
Good thing I remembered to push a jumper through every hole where it went.
I could hardly get the jumper pin into most of the holes!
If you like bending IC pins go ahead and just put your IC's in a BPS breadboard before doing this.
That's the long and short of it.
Like Bartles and James 'Thank you for your support!'
wayneh
Joined Sep 9, 2010
18,104
Like Bartles and James 'Thank you for your cooperation!'
I have no idea what you’re talking about.
PICNewbee
Joined Mar 31, 2017
355
Wayne Thank you!
Okay. Solderless breadboard.
http://www.busboard.com/BB830
Our other breadboards jumpers and PIC's just go right in.
On these BPS ones the clamps or contacts are VERY tight in the holes.
So it's a good idea to 'pre insert' or open up the contacts before trying to put IC's in there.
PICNewbee
Joined Mar 31, 2017
355
Max and Wayne Thanks
Just to be even minded about it .
They are in the whole well made.
The markings in red and blue are handy when you start getting stupid working on a project for too long.
So you don't dead short the power supply.
It's just the first time you put a PIC in one for example.
A little birdie tells you just forcing down on it is 'a bad thing'.
We will keep getting them.
be80be
Joined Jul 5, 2008
2,395
That's funny I got one of those It's good maybe the best one I have but I never bent a pin on chip I've had a time with some cheap resistors
PICNewbee
Joined Mar 31, 2017
355
Thank you Bebe!
Had to fight with this one to get the jumper wire in all the holes where the PIC was going.
Note. These are BPS jumper wires with pins on end. That's what it takes to push it in.
Lot of resistance right at the start.
Feels like it's on top of clip and is not going to go in at all.
Then they go in.
Will report how the next couple of boards work.
Getting them from same supplier.
MMcLaren
Joined Feb 14, 2010
861
Those breadboards are faulty. Julian Ilett mentioned it in a YouTube video.
I've purchased several solderless breadboards from China and two of them had the faulty connectors so I got a refund.
PICNewbee
Joined Mar 31, 2017
355
Thank you M McLaren
Well. They work just fine once you get past the 'trouble spot' at the beginning.
We'll see.
Breaktime here.
PICNewbee
Joined Mar 31, 2017
355
Thank you dl
These are Busboard Prototype Systems breadboards that we bought from one
of the big parts houses.
I hope that answers your question.
I personally will continue to buy them.
The Futurlec's are something we have not gotten yet.
