I Linear generator prototype (2 Viewers)
kusspuss
Joined Oct 17, 2025
i have basically linear generators , two on left two on right
i have selected N28 magnet and 0.65mm Cu wire(5m)
but galvanometer show no current at that stage
Generator video
kusspuss
Joined Oct 17, 2025
hi kp,
Please post a link, that we do not have to join/login to watch, also a wiring diagram would be helpful and a brief description of what the circuit is supposed to do?
Moderation.
Thank you
right now the generator design at initial stage so no wiring diagram , just a model and coil + magnet
panic mode
Joined Oct 10, 2011
5,306
from that image one cannot tell if wire is enamel coated or not.
when making coils, make sure that:
a) wire is insulated (or turns not touching each other)
b) wire ends are not insulated (so you can connect them to other parts of the circuit)
Rf300
Joined Apr 18, 2025
127
Maybe your meter is simply too slow to follow an AC-signal with about 10 Hz. Try to slow down the motor so that you have only about 1 Hz.
28,446
Without a lot more description of what the intention is, and at least a preliminary drawing of where and what the coil shown connects to, there is no point to attempting any answer to what is not a question.
My mind-reading ability is vastly less than the mind-reading ability of most of the other folks who frequent these threads.
What that means is that the TS needs to provide a much better explanation.
