I think it was supposed to be a joke.A 1.0 Ohm resistor should work. The Estes Igniter #302301 is about a 0.8 Ohm resistance and they normally fire these things with a 12 Volt lead acid battery.
I have used the MOSFET you are using with an Arduino and driving about a 0.5 Amp load, maybe only 400 mA as it was a RGB LED string but it worked fine using 5 Volts from an Arduino with a 10K gate resistor to ground. Pretty much as you drew it. This is also a good read from Estes if you haven't read it. Anyway while a 9 volt battery is not the best choice it should work as it did before for you. Something is not allowing enough current. You could try a fresh battery?
Ron
