Burning up 2n2222 trans
ulms
Joined Mar 19, 2024
194
Hello
A search on Google couldn't get me an answer. I need to switch two and a half amps at five volts. The 2n2222's are failing. What's the next size up so to speak transistor that might handle that?
SamR
Joined Mar 19, 2019
5,542
In the TO-220 maybe something like the TIP31C, NPN, 100V, 3A, 40W, MEDIUM POWER SWITCHING with a hefty heat sink is just marginal for 2.5A continuous but within spec. Maybe a power MOSFET in the TO-220 like the IRF510, MOSFET, 5.6A, 100V, 0.540 Ohm, N-Channel Power? Also, with a hefty heat sink and same for any TO-220 to dissipate heat from that kind of power through them. Someone here should be able to put a finer point on it.
WBahn
Joined Mar 31, 2012
33,263
Hello
A quick look at the data sheet explains the issue:
The absolute max collector current is 800 mA. Try to switch 2.5 A with it and it's not surprising that you are letting the magic smoke out.
Instead of trying to get Google to tell you the answer, use Google to look up the data sheet for the part of interest and then look in the data sheet for the answers you seek.
As for finding other alternatives, a good place to start is using the product selector tools at places like DigiKey or Mouser.
Reloadron
Joined Jan 15, 2015
7,962
Well a 2N2222 NPN transistor has a max current of 800 mA or 0.8 Amp and you are switching 2.5 Amps. No clue what you are trying to do but if possible my first choice would be a N Channel logic level MOSFET. Please better define your project.
Thank you WBahn for the data sheet.
Ron
ulms
Joined Mar 19, 2024
194
Ron
Hi, I'm switching 1.3 amps. Just wanted some overate.
WBahn
Joined Mar 31, 2012
33,263
That's good, and a factor of two is a reasonable starting point. Of course, that means that your actual current is still nearly twice what the transistors are rated for.
38,864
It always amazes me when someone tries to use a component where the data sheets limits are severely exceeded (by a factor of over 3 here).
Why did you not read the data sheet where it says the max 2N222's collector current is 800mA?
Note that a BJT requires a control base current of 1/10 of the collector current to turn on with minimum voltage drop, so that would be 130mA for a 1.3A load.
To reduce the control current to zero with low power dissipation, use a logic-level type MOSFET as a switch with an on-resistance of <0.1Ω, which will keep the dissipation well below 1W, so it won't require a heatsink.
ulms
Joined Mar 19, 2024
194
I was in a pinch and wanted to keep the project momentum going. I was well aware of the 800ma limitation and the 50 cent transistors did last long enough to prove the circuit out. I ordered what Samr suggested. Today I'll put two in parallel I was in a rush yesterday, my girl calling me up from the basement to mow the lawn and all.
Reloadron
Joined Jan 15, 2015
7,962
How are you planning to drive the TIP31C transistor? I hope whatever you plan has the available drive current.
Initially you mentioned:
You also want to handle a stall current if you are driving a motor. Anyway a 1.3 amp load will need about a 130 mA base drive current. If you plan to use a uC like an Arduino you better start thinking MOSFET, like a FQP30N06L or similar.
Ron
dl324
Joined Mar 30, 2015
18,478
Apparently you didn't understand what the absolute maximum rating meant.
From OnSem 2N2222A datasheeti:
Some datasheets go further and state that devices might not survive the absolute maximums.
BobaMosfet
Joined Jul 1, 2009
2,211
Hello
What you're looking for is an IRLZ44N. Logic level FET that can handle the current.
schmitt trigger
Joined Jul 12, 2010
2,260
From the “burn the transistor first, ask questions later” school of thought.
It is a common mistake that many rookies make. I certainly smoked a few components myself in the early days.
But one has to learn quickly from the mistake. And an essential knowledge is how to read datasheets.
I know, I know. At first all that information may be overwhelming. But if one wants to design anything beyond an Arduino flashing an LED, reading and understanding datasheets is a must.
BobaMosfet
Joined Jul 1, 2009
2,211
Learning mosfets, is that a whole new ball game? I barely have a handle on bpj's. Thank for the above info.
In this vein, using a Mosfet is superior because you use voltage to switch current with a MosFET, not current to switch current (like a BJT). How much current a device handles is a function of how hot it's internals (junction temperature) can get (and be dissipated). Use a heatsink.
