Burgler Alarm Circuit
EdgyNinja
Joined Jun 8, 2017
7
Hey guys I'm new here and my class is having a practice test project. Our teacher instructed us to pick a circuit of our liking to make in a weeks time. But before I go out and buy the components, I want to make sure that this circuit would work. Thanks for your help.
Moderators note : showm image full size
Reloadron
Joined Jan 15, 2015
7,887
Off the top it looks like you are using the 741 as a comparator. R2 & R3 form a divider leaving about 3.4 Volts as a voltage reference on the 741. The old 741 is really a poor choice as a comparator. A better choice would likely be a comparator chip. This is a very good read on comparators and for a single comparator I would likely choose the LM311 which is a single comparator. Read the link. Then VR2 looks to be used for hysteresis and if that is the case you want hysteresis tied back to the + (non-inverting) input. If you scroll down the link you will see hysteresis applied in comparator circuits. I would think about moving the LED up into the collector circuit of T1 the BC 548 NPN. That is as far as I looked.
This would go better if you explained your circuit operation so those viewing it know what you had in mind and your expectations of the circuit.
Ron
Reloadron
Joined Jan 15, 2015
7,887
The entire circuit uses old and or obsolete parts. While the LM741 continues in production it is what? Pushing maybe 50 years old?
Ron
EdgyNinja
Joined Jun 8, 2017
7
Guys, I have the UM3651, and alternative parts for the rest. I tried this circuit and it doesn't work. Someone from Electronicspoint told me this circuit is full of errors. I would love to learn what is wrong with this circuit and fix it.
Reloadron
Joined Jan 15, 2015
7,887
What exactly are you wanting this circuit to do? As it looks the 741 which I mentioned is used as a comparator and is a poor choice. R2 and R3 form a voltage divider. Here is an example of using the 741 as a comparator. The problem is in your circuit the divider network is going to the non-inverting input (pin 3). A simple Google of 741 as a comparator will yield other examples. The inverting and non inverting inputs are drawn wrong! When the input exceeds 3.4 volts the output will go low when it needs to go high. I suggested earlier you read and understand comparators, I suggest again you read about comparators. You are trying to build a circuit which is a poor design and don't understand how it should work. Next the idea is for the 741 to swing its output and turn on T1 an NPN transistor. When T1 turns on, even momentarily it pulls (or should pull) pin 2 of the 555 timer IC 2 low triggering the 555. The 555 Timer (IC2) is configured as a One Shot so I suggest you read using the 555 as a one shot timer. R6 and C2 determine the timing of the output pulse at pin 3 of the 555. Read the 555 data sheet to understand timing. Your drawing would have a pulse out of about 110 seconds.
The 555 output pin 3 is being used to power your sound generator chip the output of which is amplified by T2. Since this is your project shouldn't you know how it works or should work? The Internet is loaded with poorly designed circuits which do not work. This is pretty much the same response you got in other forums you placed this circuit in. If you want one that works you need to understand what is going on and why.
Ron
EdgyNinja
Joined Jun 8, 2017
7
Thank you Ron. You are right. I really don't understand and I am in the process of learning. Yes this circuit is full of errors. I am going to take the time to understand why it DOESN'T work, which would benefit me greatly. I would love more help understandin why I doesn't work. BTW this circuit is suppose to trigger the alarm when the mic picks up sound.
http://www.electroschematics.com/5346/panic-alarm/
Here is the link to the web page. Thanks again, this is interesting.
Reloadron
Joined Jan 15, 2015
7,887
Yes, it is sound activated, when a sound passes a preset threshold the process begins. The 741 inputs are backwards for starters. The non inverting input is the + and the inverting input is the -. I would switch those for starters. Again, I see the LM741 as a poor choice for a comparator but it should work with the inputs switched.
Ron
EdgyNinja
Joined Jun 8, 2017
7
Ron
So all I have to do is switch the inverting inputs and it will work?
AnalogKid
Joined Aug 1, 2013
12,126
I don't think so.
The 741 is an adjustable-gain inverting linear amplifier. T1 with the LED in the emitter is the comparator. When the 741 output goes below approx. 2.4 V, T1 turns off and R5 pulls 555 pin 2 up to 12 V. When that audio half-cycle goes high, T1 turns on and pulls 555 pin 2 below 4 V to trigger the monostable.
R4 should be 2.2K.
Also, as soon as I power on, the alarm sounds right away. Something is triggering the 555 besides the mic
The 555 powers up with pin 2 low, the trigger condition. That is a flaw of the design.
ak
EdgyNinja
Joined Jun 8, 2017
7
I don't think so.
R4 should be 2.2K.
ak
Do you have any idea how to fix this circuit?
AnalogKid
Joined Aug 1, 2013
12,126
On further thought, there might be other problems with the circuit. Other, as in it might never turn off the audio. Hmmm ...
Is your assignment to blindly assemble something you don't understand, or do a little circuit design work?
ak
Reloadron
Joined Jan 15, 2015
7,887
I don't think so.
R4 should be 2.2K.
ak
You may want to heed what AnalogKid has to contribute as he is much better than I at diagnosing this circuit. I was seeing the 741 as a
comparator which I had wrong.
Ron
EdgyNinja
Joined Jun 8, 2017
7
It was my fault for picking up something I don't understand for my assignment. However, I'm really keen on figuring out how to fix it.
ak
