Building chronogram for this circuit
salhi
Joined Nov 29, 2023
86
Im tasked to plot the chronogram (evolution in-time) of this circuit in terms of \( Q_1, Q_2, Q_3 \) but i dont know the initial conditions of D
Is it really possible to do such task?
Ian0
Joined Aug 7, 2020
13,185
Yes.
True. You don't know D, but for a first attempt assume that your D-latches have a power-on reset (so Q1, Q2 and Q3 all start at zero).
When you have done that, are there any of the eight possible states for which you don't know the next state?
If so, repeat the exercise starting at any states for which you don't know the next state.
salhi
Joined Nov 29, 2023
86
infinite thanks everyone , so regardless of the state of initial D, the pattern will be periodic whether its 1/0 ?
salhi
Joined Nov 29, 2023
86
Can you have a look at circuit again because i think you are confused about how the inputs of each D-FF
eetech00
Joined Jun 8, 2013
4,712
Study how a D flip flop works. Here's a truth table.
And remember, the DFF you show is a positive clocked device, so it will only change state on the RISING edge of the clock.
Then, go back and re-think your graph in post#7.
salhi
Joined Nov 29, 2023
86
yea my first cycle is correct, if you think its wrong point it out im pretty sure what i did for the first clock cycle is true
dl324
Joined Mar 30, 2015
18,433
okey whats wrong with it?
Did you read post #15?
On the rising edge of the first clock, the input to FF1 is 1, but the inputs to the other 2 are still 0. You show all outputs changing to 1 at the first clock. That's wrong.
salhi
Joined Nov 29, 2023
86
well thats wrong why you think the inputs to the other two D-FF is still zero?
