Broken power supply!
Mikkel Offersen
Joined Dec 3, 2017
hello
I have a power supply circuit board that when I turn on the machine it start for 1 second and turn off and continues until I switch off the power
I have tried to change all the capacitors but still do not work.
What could be the reason it does?
Thanks!
AnalogKid
Joined Aug 1, 2013
12,238
Without a schematic it is impossible to say. If the output comes up to the correct voltage and holds there briefly, then the front end is at least partly functional. During that 1 second is the output correct, or higher than normal?
ak
Mikkel Offersen
Joined Dec 3, 2017
ak
Yes the output is normal in Thatcher 1 second.
I have also tried removing the motor conection and then evrything works except the motor
