bridge rectifier gets too hot
ulzi
Joined Dec 16, 2018
11
guys, pls see pictures of curcuits and advice me .
by 1,2 cutcuits , it is ok , all working good.
but by circuits 3 , problem .
bridge rectifier gets too hot very fast , and variac is humming, ( seems a lot current draws from variac to capacitor. )
i have no idea how to fix this , and can't understand what is going wrong
pls ???
LesJones
Joined Jan 8, 2017
4,536
A variac does not give any isolation. (It is an autotransformer.) One side of your signal source is probably connected to ground which will be shorting out diodes in the bridge rectifier. Use a proper isolating transformer.
Les.
ulzi
Joined Dec 16, 2018
11
Les.
Les , thanks
so, you mean , don;t use variac, instead of variac use simple step down transformer??
LesJones
Joined Jan 8, 2017
4,536
Yes, Or have a 230 V to 230 V isolating transformer between the mains supply and the variac. The problem is that the neutral side of the mains is connected to ground at some point in the power distribution system. So as you are grounding the negative output of the bridge via the signal source some of the diodes will be shorted out.
Les.
ulzi
Joined Dec 16, 2018
11
Les.
Aaaan , I seeee, Understood well. Les , thank you very much.
may i put isolation transformer between the variac and capacitor ?
LesJones
Joined Jan 8, 2017
4,536
You can use any solution that provides a floating AC supply to the input of the bridge rectifier.
NOTE you may have allready destroyed some of the diodes in the bridge rectifier.
Les.
