How to calculate the resistor and capacitor values for a bridge diode full-wave rectifier?
okasian
Joined Dec 2, 2024
Hello. I need to design the circuit so that the output power is 1W, but I'm not sure what values to use for Rs and Cout. Could you explain how to calculate them?
WBahn
Joined Mar 31, 2012
33,198
To actually calculate them, you need more information that you have provided since the values depend on the interactions with other devices in the circuit.
Even then, there are (at least potentially) considerations that are specific to the internals of the IC you are using.
This is why the first place to start is the manufacturer's data sheet for that IC. What does it have to say about the capacitor values?
What is the purpose of Rs? Why might you want it to be anything other than zero ohms?
okasian
Joined Dec 2, 2024
Actually, I didn’t design this circuit myself; it’s a school assignment.
The purpose of this calculation is simply to determine the values of Rs and Cout so that the output power becomes 1W, so there isn’t a specific purpose behind it.
WBahn
Joined Mar 31, 2012
33,198
What does the output power depend on? Specifically, the voltage where and the current where?
Given those values, what does Rs have to be in order to achieve them?
What constraints, if any, do these values place on Cout?
okasian
Joined Dec 2, 2024
The output power depends on Vout and the output current value of 200 mA.
To achieve this, I’m not exactly sure what the value of Rs should be.
I just hope that Rs is a value that allows the output power to be 1W.
I think these values do not impose any constraints on Cout.
WBahn
Joined Mar 31, 2012
33,198
Well, if the output current value is 200 mA, what must Vout be in order to deliver 1 W?
What is the output voltage of the 7805 regulator?
What is the voltage drop across Rs under the needed conditions?
What is the current through Rs under the needed conditions?
What must Rs be in order to satisfy the needed conditions?
If those value do not impose any constraints on Cout, the what does that tell you that you can choose for Cout?
35,180
Have you considered that this could be a trick question?
Power delivered to a load, i.e. 200mA @ 5V, depends on the resistance of the load, and not on Rs or Cout.
How does the value of Rs affect the wattage at the load?
How does the value of Cout affect the wattage at the load?
MrAl
Joined Jun 17, 2014
13,793
This is an unusual question because the capacitor Cout only sees a DC voltage not a varying voltage where a capacitor is usually needed. You might have to ask about that.
You can start by writing a simple equation for the output power assuming you actually knew the output load resistor, call it maybe RL for example. The solution will then have both Rs and RL in it. You can only get a numerical solution though when RL is known, perhaps at a later date.
35,180
Actually, the answer to the question is easier than you think.
All you need to know are two formulae, Ohm's Law and the formula for power.
Let's start with Ohm's Law and its two derivations:
I = V / R
R = V / I
V = I x R
The power formula and two derivations are:
P = I x I x R
P = V x V / R
P = V x I
All you need to do is select one formula from the two groups.
If you are given the current and the power, calculate the load resistance:
R = P /( I x I)
Now that you know the load resistance, calculate the voltage across the load:
V = I x R
What does this tell you about the value of Rs?
WBahn
Joined Mar 31, 2012
33,198
There is no need to calculate the load resistance. Yes, it needs to be a specific value, but there is no reason to ever calculate what that value happens to be.
MrAl
Joined Jun 17, 2014
13,793
I'm not sure about that now. If we know the current and the power in RLoad we can calculate the only possible RLoad, and once we know the RLoad we can calculate the required voltage across RLoad, then we can calculate the require Rs resistance.
I don't want to mention the 'range' of Rs though just yet :)
I updated by previous reply also.
WBahn
Joined Mar 31, 2012
33,198
Come on guys. Do the math!
The TS has stated that 1 W has to be delivered when the current is 200 mA.
Do you REALLY need to know what the load resistance is in order to figure out what the voltage Vout has to be in order to deliver 1 W when the current is 200 mA?
If you know what Vout is and you know what the current is and you know what the output of the 7805 regulator is (at least nominally), how hard is it to determine, by inspection, what the only possible value of Rs is?
WBahn
Joined Mar 31, 2012
33,198
I don't know that it's so much a trick question as a pointless one and one that likely indicates that the person that crafted it has never designed a circuit that had to work anywhere but on paper.
MrAl
Joined Jun 17, 2014
13,793
Oh yes you are of course 100 percent correct, but I think in the course of proving what the value of Rs should be, we have to do a little more math and that, I believe, should include actually calculating the value of Rs. It would end with a math statement like Rs=N where N was whatever the calculation came out to be resulting from the previous calculations.
Maybe we can say that what you are suggesting *is* enough proof though, that's a possibility I agree.
What is unusual though is the capacitor as it's a pure DC circuit. Could that have the same type of 'proof'.
WBahn
Joined Mar 31, 2012
33,198
And why do we need to calculate a value for RL to calculate the value of Rs?
wayneh
Joined Sep 9, 2010
18,164
The data sheet will also point out that placing a capacitance there suggests adding a reversed bias diode across the regulator, to protect the regulator. Otherwise, if power is removed, the capacitor discharges back through the regulator and this can destroy it.
This is commonly overlooked and people get away with it but every 7805 data sheet I've seen mentions it.
WBahn
Joined Mar 31, 2012
33,198
IIRC, that diode is only needed if the output capacitor is larger than about 10 µF, which is 100x the recommended value.
35,180
For someone with zero knowledge of electronics, the question is irrelevant.
For someone with introductory knowledge of electronics, the question is trivial, to the point of being pointless.
Where does the TS stand? Or what is the level of expertise of the instructor?
MrAl
Joined Jun 17, 2014
13,793
Oh yes forgot about that, I remember something like that with the LM317 regulator. I don't remember all the specifics for either regulator though.
