Bosch control module blown chip
Trickyhat
Joined May 10, 2019
6
Heya,
I have a Bosch washing machine that isn't working properly (motor starts and stops straight away). Thought I'd have a look at the mainboard (power module) and found scorching around one chip. I cannot Identify it but it seems to have shielding around it for heat?
Is it possible to identify this chip without being able to read the print on it?20190510_151923.jpg 20190510_151923.jpg 20190510_151918.jpg
The part number is bosch 11005213
I have little knowledge of electronics but am keen to learn.
Trickyhat
Joined May 10, 2019
6
Ok. Have just worked out that it's a Triac transistor common in washing machines for motor control. But I still can't identify the type.
Trickyhat
Joined May 10, 2019
6
Debe,
Thanks for the advice. Never having tested a motor b4 I assume it's just a matter of testing the windings with a multimeter and...
