I would use a DMM, Digital Multi-Meter.How to check CHG_IN_5V(C565)=5V and how to check Check V_BUS_5V(C563) =5V
In manual: P8-93
- Put the black lead on a suitabe GND point.
- Put the red lead on the respective pins of U501.
In manual: P8-93
The 20V range is a bit high, do you have a lower one? Needing the battery is a good question. If the chip that is the source oe the OTG_EN signal requires the battery, then yes I think you'll need the battery.Is the mod 20 DCV on multimeter and when I measure voltage do I need to put battery of android?
I want to convert 3.8 volts to 5 volts.
What will you connect to the 5 volts?How can I now that?
Does your device support USB OTG (USB On The Go)?USB OTG devices.
