Bodeplot of simulation and network analyzer difference in magnitude with same characteristics
kwoki
Joined Aug 31, 2018
12
I have a problem which I can't find the solution. It's related with the determination of the bodeplot of a circuit. According to my bodeplot in the simulation, the flat part of the magnitude plot is -23.02 dB (Simulation.PNG) and the cut-off frequency is equal to 17.67 MHz whereas the flat part of the magnitude plot from the vector network analyzer (Help_VNA) is around -7 dB and the cut-off frequency is around 20 MHz.
Moreover, the frequency characteristic seems the same as given in the simulation, but the magnitude is different. Does anyone know why there is a difference?
Network analyzer:
flat part at -7 dB and cut-off frequency at -10 dB
Simulation:
flat part at -20.02 dB and cut-off frequency at -23 dB
I am using an Agilent 4395A network- spectrum and impedance analyzer with Agilent 87512A which is attached to input A and R.
Papabravo
Joined Feb 24, 2006
22,102
The usual reason for such a shift would be assumptions about source impedance and load impedance. Given the frequencies and the negative magnitudes I'm guessing this is a passive filter.
kwoki
Joined Aug 31, 2018
12
It's actually a Transimpedance amplifier. I have added a two files how I got the result (Help_vna.png). Is this the right way to connect and to measure the bandwitdh?
