MisterBill2
- Joined Jan 23, 2018
- 28,522
It is certainly true that a direct connection between the terminals and the external power supply would be a fairly direct short circuit. BUT how many of the "average consumer" folks would actually bypass their existing doorbell sounder device?? Most folks will have a hard time getting the wires to stay under the screws, even. So for the blink installation, either leave the present (if it works) bell in series, or put a series 33 ohm, 1 watt resistor in line with the power source.
Several years ago I installed a "RING" doorbell for a handicapped senior person. That came with all sorts of instructions, none which applied because the doorbell was not working at all. When the original batteries ran down they had it removed because they had no clue, and they had discarded all of the instructions and had no clue about battery replacement. (Off Topic, I suppose)
