BJT transistor
ericgibbs
Joined Jan 29, 2010
21,571
ericgibbs, that link teaches how to read values on a grid? Come on... I thought it was something else... I know how to read values on a grid...
But in that plot I have the curves upside down with negative values for Ic. The curves are like mirrored in the X axis comparing with the previous BJT!
Sorry, I do not know of another way to say 'they are not upside down'.
Its a PNP transistor, that has a negative Vce and a negative Ib current, so the Ic values will be shown as negative current values.
If you read the LTS help topics it explains how it decides the conventional current flow direction.
I do not understand why you consider it as a problem.?:)
Relook at the post #58 images.
EDIT:
Also post #46 image
PsySc0rpi0n
Joined Mar 4, 2014
1,786
No, I'm not considering a problem... Just asking if it was correct and I aws asking for a small explanation about why it happens comparing with the other BJT!!!
