Beginners Capacitors
Dal1980
Joined Aug 30, 2015
19
A long time ago at school I was taught that a capacitor was like a barrel with a hole at the bottom (+) and a hole at the top (-). Electricity would act like water and come in at the bottom (+) and begin filling the barrel until it eventually was full/charged enough to allow the flow of water/electricity to flow out the top (-).
After reading about capacitors again it appears that this is actually the reverse of what I was taught? Only when the barrel was full does the flow stop.
Experiment
Battery (measuring 2.5v according to my multimetre)
LED
Electrolyte Capacitor 100uF (10v?)
Attached Battery + to + leg of Cap
- Leg of Cap to + of LED
- Leg of LED to - Battery
LED was lit and waited 20 or so seconds. LED has not flashed or changed at all.
Should the capacitor not fill and stop the flow of electricity thus turning off the LED?
cmartinez
Joined Jan 17, 2007
8,765
According to my sim. The LED will only light up for a fraction of a second and will stop after the cap is fully charged. And although a voltage remains across the LED (about 1.4V) due to it's inherent voltage drop, no current will flow through it.
ScottWang
Joined Aug 23, 2012
7,501
The polarity of capacitor was wrong, it could be damaged, now it isn't damaged, because the voltage is too low and the time is not coming, but someday it will.
The led didn't flash because the capacitor didn't discharge.
Dal1980
Joined Aug 30, 2015
19
Wrong way Blocco? I thought the short leg was negative... actually, forget my diagram... I'm new to them too :oops::oops:
Oh dear, this is not going well for me :(:)
18,104
Haha, glad to see I'm not the only one. Having two options causes a few errors, Murphy's law and all. When there are 3 or more options to consider (like 3-way switches), it's a miracle we ever get it right.
ScottWang
Joined Aug 23, 2012
7,501
You just take easy for your error, I involved EE close to 40 years, I still make some errors, and I will also make mistake in the feature, unless you left EE behind, otherwise you can't prevent it completely, only can be reduce.
You just need to learn more basic theories and refresh your memory, go go go ... :)
Dal1980
Joined Aug 30, 2015
19
No resistors are in my circuit but had the LED lit for a good 5 minutes at least. Using 2.5v (2x AA batteries).
