BCD to 7 segment for hardware code issue
Dija Angel
Joined Oct 1, 2021
24
Hello everyone!I have a hardware for a bcd to 7 segment.I am trying to make the common cathode count from 0 to 9 and the common anode from 9 to 0 using two switches for each of them.They dont count properly and display random numbers when it counts. I'm using an msp430.
C++:
#define buzzer 5
#define LED1 6
#define LED2 7
#define SW1 8
#define SW2 9
#define Freq 2
const int E3= 3 ;
const int AA0= 4;
const int D0= 10;
const int D1 =11 ;
const int D2= 12;
const int D3= 13 ;
int seg1=9;
int seg2=0;
void setup(){
pinMode(buzzer,OUTPUT);
pinMode(LED1,OUTPUT);
pinMode(LED2,OUTPUT);
pinMode(SW1,INPUT);
pinMode(SW2,INPUT);
pinMode(AA0, OUTPUT);
pinMode(E3, OUTPUT);
pinMode(D3, OUTPUT);
pinMode(D2, OUTPUT);
pinMode(D1, OUTPUT);
pinMode(D0, OUTPUT);
  digitalWrite(LED1,LOW);//active low because it turns it on
  delay(250);
  digitalWrite(LED1,HIGH);
  tone(buzzer,440,250);//RED
  delay(250);
  digitalWrite(LED2,LOW);//active low because it turns it on
  delay(250);
  digitalWrite(LED2,HIGH);
   tone(buzzer,294,250);//RED
  delay(250);
void loop()
 if(digitalRead(SW1)==HIGH){
 while(digitalRead(SW1)==HIGH){}//while the button is pressed
 for(int i=0;i<=seg1;i++){
 disp1(i);
 delay(1000);
 //seg1++;
  if(digitalRead(SW2)==HIGH){//Switch is active LOW
  while(digitalRead(SW2)==HIGH){}//while the button is pressed
  //seg2--;
 for(int a=9;a>=seg2;a--){
 disp2(a);
 delay(1000);
/*void disp(byte digit, byte num)
  digitalWrite(D0, num & 1);
  digitalWrite(D1, num & 2);
  digitalWrite(D2, num & 4);
  digitalWrite(D3, num & 8);
  // Select which BCD to 7SEG chip to load
  digitalWrite(AA0, digit & 1);
  digitalWrite(E3, HIGH);
  digitalWrite(E3, LOW);
void disp1(int num){ //this method entails making 0-9 combinations using the BCD pins by sending different outputs to turn each segment on or off.
  digitalWrite(AA0,LOW);
  if(num == 0)//0000
    digitalWrite(D0, LOW);
    digitalWrite(D1, LOW);
    digitalWrite(D2, LOW);
    digitalWrite(D3, LOW);
  if(num == 1)//0001
    digitalWrite(D0, HIGH);
  if(num == 2)//0010
    digitalWrite(D0, LOW);//0
    digitalWrite(D1, HIGH);//1
    digitalWrite(D2, LOW);//0
    digitalWrite(D3, LOW);//0
  if(num == 3)//0011
    digitalWrite(D0, HIGH);//1
  if(num == 4)//0100
    digitalWrite(D1, LOW);//0
    digitalWrite(D2, HIGH);//1
  if(num == 5)//0101
  if(num == 6)//0110
  if(num == 7) //0111
  if(num == 8) //1000
    digitalWrite(D3, HIGH);//1
  if(num == 9)//1001
void disp2(int num){ //this method entails making 0-9 combinations using the BCD pins by sending different outputs to turn each segment on or off.
  digitalWrite(AA0,HIGH);
  if(num == 0)//0000
  if(num == 1)//0001
  if(num == 2)//0010
  if(num == 3)//0011
  if(num == 4)//0100
  if(num == 5)//0101
  if(num == 6)//0110
  if(num == 7) //0111
  if(num == 8) //1000
  if(num == 9)//1001
