Soldering Issue on SMD 7-Segment Display
akash123kumar
Joined Aug 13, 2025
11
I am using an SMD 3-digit 7-segment display in my design. The display’s pin width is around 2.20 mm and the gap between two adjacent pins is only 0.34 mm. I created the footprint in Altium exactly as per the component datasheet.
During assembly, I am facing solder-bridging / shorting between two nearby segment pins. Because of this, when I flash code to display “888”, all segments glow correctly (because all pins are driven high).
But when I display other characters or alphabets, some segments do not light properly due to the short between two pins. The display output becomes incorrect.
I want to understand:
  1. Is the pad-to-pad spacing (0.34 mm gap) too small for reliable manual soldering?
  2. What footprint dimensions or solder-mask dam width should I use to avoid bridging?
  3. Is there any recommended mounting alternative for SMD 7-segment displays (adapter board, carrier PCB, etc.) to make soldering easier?
Any guidance on proper pad size, mask clearance, or best practice for hand-soldering SMD 7-segment displays would be very helpful.
WBahn
Joined Mar 31, 2012
33,325
There are numerous techniques for soldering SMD components by hand. It requires a balance of the right equipment and the right skills -- up to a point, you can trade one for the other.
As already noted, your pads do not need to be as wide as the component pins.
The part of the datasheet you included shows the component dimensions, not the recommended PCB footprint. Does the datasheet provide that?
Even if it does, it is intended for automated assembly and may need to be tweaked for manual work. Try making your pad width between 1.8 mm and 2.0 mm.
If you have a fine-tip soldering iron and some kind of magnification, that will help you tremendously. Fortunately, 2.54 mm is not fine pitch, so it should be too difficult.
Be sure to inspect your work for solder bridges. You can use solder wick or a solder sucker to remove excess solder and break bridges. Simply blowing the excess solder away can work, too, though it does leave open the possibility that the solder ended up someplace you would rather it didn't.
