Battery measurement with Capacitor Voltage Divider & ADC
ronsimpson
Joined Oct 7, 2019
4,811
Changed many things. Slowed it down. Ron=100 ohms to not suck the battery down. Cap = bigger.
Measure the time it takes for the voltage to charge back up to 2V. The time is related to C, R and Battery voltage.
The "my switch" is a pull down MOSFET or IO port pin.
Kevil
Joined Jun 28, 2020
224
hi k,
That error message is showing a problem in U1 the OPA.
Try a OPA from the LTS library F2.
E
I don't have the CA3140 in ...\Documents\LTspiceXVII\lib\sym\OpAmps but in Bordodynov library Sborka.lib in ...\Documents\LTspiceXVII\lib\Bordodynov\lib\sub
Maybe it could help me if you can copy here the lib description for CA3140 from your lib file. E.g.:
.subckt CA3140 1 36 15 20 12
*START OF DECK
* +IN -IN OUT +VSS -VSS
*NODE: 1 36 15 20 12
*------INPUT STAGE-------
VOSBAL 7 29 3.00000000E-03
Kevil
Joined Jun 28, 2020
224
Hi ericgibbs,
Please can you post a detail graph with single red spike V(n003)? I have SPICE model of the MAX40023 Op Amp for OASIS SIMPLIS simulator and I am working on the simulation. Thank you.
Kevil
Joined Jun 28, 2020
224
It looks like it should be possible to measure the battery voltage with capacitor voltage divider, Op Amp and ADC.
Ian0
Joined Aug 7, 2020
13,278
Not with the circuits in post #11. There is no capacitive divider! It is just a unity gain buffer and its output has a capacitor to ground (surprised it is still stable) and a bootstrap capacitor to the input. The output is 3.3V because the op-amp is powered from 3.3V and it is in clipping, because its input is at 4.4V
Kevil
Joined Jun 28, 2020
224
I didn't notice that the "-" input of the op-amp is connected to C2, which it shouldn't be. The op-amp should work as the voltage follower.
I am going to simulate the circuit with MAX40023 op-amp in OASIS SIMetrix simulator. SPICE data for MAX40023 are available here.
ericgibbs
Joined Jan 29, 2010
21,569
hi Kevil.
I have no idea how that asc file was changed.???
My PC version of the asc file is the same as the original you posted... very strange.
Apologies for an inconvenience it may have caused.
E
Ian0
Joined Aug 7, 2020
13,278
If both divider capacitors are the same physical size, and you assume 10GΩ of pcb surface leakage across each, within a minute the voltage on the inverting input of the op-amp will be half the battery voltage. If the actual surface resistance varies due to contamination, then it could be anywhere between 0V and full battery voltage.
Kevil
Joined Jun 28, 2020
224
I run the single 250 ns ADC battery voltage measurement each hour. When I unplug and plug again the development board (ATSAMR34- Xplained, without Op Amp) to USB port before each meaurement I am getting pretty steady right results. When I keep the board plugged the measured voltage decay. First picture Vbat 4.V and two other pictures Vbat 3.3V.
Ian0
Joined Aug 7, 2020
13,278
That’s because capacitive dividers don’t work with DC. @MrSalts said that in post#2, and many people have suggested alternative schemes.
If you return to the capacitive divider you return to a circuit that doesn't work. Of course, you can use SPICE to make it look as though it might work, but SPICE uses perfect components, with no leakage resistance.
Put 10GΩ across each of your capacitors and run it again.
Kevil
Joined Jun 28, 2020
224
I have just added TI LMC6482 (without the C=0.1µF) to capacitor voltage divider and I am getting rock steady ADC values without any problem. For 4.12Vbat 214 (0xD6) and for 3.3Vbat 162 (0xA2). ADC 8-bit resolution, Vref 3.3V and sampling time 250ns.
