Battery terminals; cleanable? Or Toast?
B-JoJo-S
Joined Jan 3, 2026
600
Just got this Christmas Train Set - battery powered. Runs on four C cell batteries. When I opened the battery compartment the batteries that were in them were ALL OF THEM Leaked. They have been in there for many years. Possibly a decade or longer. Consequently the corrosion is extensive. Any suggestions on how to clean the terminals? Can the battery terminals be cleaned sufficiently to make contact with new batteries? Or should I scrap the whole thing. Maybe modify it to hold two 18650's? Would have to include BMS to prevent over discharging and to control charging at proper rates? Ideally would like to put four 18650 in the coal tender but I don't think there would be enough space. Wonder if there's a flat pack Li-Ion battery that can be fitted into the tender. Looks like the best I can do would be two 18650's.
WBahn
Joined Mar 31, 2012
33,325
It's hard to tell just how bad it is, but it looks like there's a fair chance to save it the existing contacts. Use cotton-tipped swabs and white vinegar to gently scrub the contacts. A tooth pick can help chip off the residue and corroded flakes. When finished, some fine sandpaper can expose good metal so that you can get a good electrical contact. Unless you're going to be running this thing a lot, I wouldn't mess with trying to fit in a rechargeable battery pack. Plus, doing so would serious reduce any vintage toy value it might have.
B-JoJo-S
Joined Jan 3, 2026
600
Thank you. As for it being "Vintage" I'm not so sure it has much value in that arena. It's all plastic. Now, if you want Vintage? I wish I had the train I once had when I was a child. All metal construction with a siren consisting of a fluted fan and cage covered by a louver that slowly opened and closed to mimic the train whistle - wwwWWWWWwwwwwWWWWWwwwwwWW - WWWWWwwwww. They don't make them like that anymore. Nowadays they have electronic sounds that are cheesy at best.
Back to this train: Thanks for the vinegar tip. I have some industrial vinegar out in the garage. I wouldn't use it in the house, the fumes are killer strong. I'll give it a shot tomorrow sometime.
I actually got two train sets, both battery powered. The other one hasn't had batteries in it yet - I don't think. It's clean and slightly bigger than the one I'd like to refurbish. Tracks are not the same size so I can't mix / match them together. "(
B-JoJo-S
Joined Jan 3, 2026
600
It's hard to tell just how bad it is.
Really bad. I've never seen such bad corrosion before.
This is why I wonder if it's better off getting something else in there with near the same Ah rating. I've seen This and they're small enough to put two of them in the battery compartment wired in parallel. BUT - I don't know what kind of BMS would be required.
"Li-Mn02". Totally unfamiliar with that battery.
Never mind. Says "DO NOT RECHARGE".
35,280
Still salvageable.
Firstly, clean with water and a toothbrush. Scrape away any solid deposits. Use a metal file and clean all surfaces that will contact the battery. Rinse with IPA (isopropyl alcohol). Blow dry.
Don’t substitute the batteries with 18650. Use the required C cells.
28,520
I suggest scrubbing with a mix of baking soda and water, followed by a good rinsing. THAT should remove most or all of the corrosion and battery juice. If the first time does not work, do it again.
robp1956
Joined Jun 12, 2026
121
Nope the best thing to use is vinegar the weak acid neutralizes the stronger acid far better than Baking soda with a nice wire brush with fine bristles and that will clean the corrosion off and then fine sandpaper to get to some bare metal. I have cleaned many of these contacts in old toys and that has always worked a treat for me.
28,520
After the terminal is cleaned, and copper is visible, Tinning it with a bit of solder will make it less likely to corrode again. BUTCAUTION is needed when melting solder on the terminal because the plastic enclosure does tend to melt. So you will need flux-core solder and you do need to work rapidly!
B-JoJo-S
Joined Jan 3, 2026
600
Well SHUT MY Mouth! It works.
Doesn't look pretty - but who cares ? !
I removed the terminals and began scraping the black off that was under the blue corrosion. Was having a hard time with that so I fluxed it then ran solder all over the surface. The black "Tar" came up with some effort but not a lot of effort. Cleaned them up and rebuilt the internals. Darn thing has a very loud Christmas speaker under the coal tender. Glad I can shut it off. Obnoxious for sure.
Anyway: Thanks for the assistance.
panic mode
Joined Oct 10, 2011
5,431
really? i think that looks rather good, yes it is rusted but the spring coil is still structurally sound, there are still some bones in it.
things are not so good with columns supporting overhead railway in Chicago.
i recall seeing same thing while crossing bridge between Detroit and Windsor.
so i would say just clean it with a brush or sponge in acid bath (vinegar or lemon juice). it will be like new (in terms of performance, not looks).
Ya’akov
Joined Jan 27, 2019
10,356
That is genuinely scary.
panic mode
Joined Oct 10, 2011
5,431
i composed my post but was called away (troubleshoot something then do some soldering...). when i came back and i clicked on "post reply" and sure enough there was more posts. i chose not to delete it because although you did make it work (congrats) that could be cleaned a bit better. if not treated, next year you will see the rust spread again even without more of leaking chemicals. ;)
B-JoJo-S
Joined Jan 3, 2026
600
I won't be seeing it next year. Once it was working I put it on the tracks and it could hardly pull the load it was designed to pull. Motor was working just fine. Gears were noisy as all get-out. So after that work I decided not to keep it. It left this morning, never to be seen again.
You might say it was all for nothing, but that's not true. I learned something important. Not to accept things that people have held on for decades with old batteries still in the battery compartment. Also learned that I can clean it.
panic mode
Joined Oct 10, 2011
5,431
are you sure it is not just bad contact? after all, that still looks rusty. i would solder wires and connect to separate battery pack or PSU to test it...
