Although I have Bordodynov library. I got error when I run the simulation. What's wrong?hi Kevil,
Seems to be a OPA model problem.
For test used a CA3140.
E
I don't have the CA3140 in ...\Documents\LTspiceXVII\lib\sym\OpAmps but in Bordodynov library Sborka.lib in ...\Documents\LTspiceXVII\lib\Bordodynov\lib\subhi k,
That error message is showing a problem in U1 the OPA.
Try a OPA from the LTS library F2.
E
Not with the circuits in post #11. There is no capacitive divider! It is just a unity gain buffer and its output has a capacitor to ground (surprised it is still stable) and a bootstrap capacitor to the input. The output is 3.3V because the op-amp is powered from 3.3V and it is in clipping, because its input is at 4.4VIt looks like it should be possible to measure the battery voltage with capacitor voltage divider, Op Amp and ADC.
hi Kevil.I didn't notice that the "-" input of the op-amp is connected to C2, which it shouldn't be. The op-amp should work as the voltage follower.
