Basic electronics, configuration of OPAMP circuit on breadboard
OPTSimon
Joined Mar 24, 2021
33
Hello everyone,
I am an optical Engineer, with a little electrical experience, but it has been a long long time ago since i have made any kind of circuits my self, however that is the "case"here, so i am hoping some one would be willing to assist me.
Normally i would just purchase the component i need, but due to corona, the waiting time for the "dongle" is simply to long, so i ordered the components my self and though i should be able to do this my self - but after two days where i still cant figure out what i have done wrong, i am looking for some help :)
So the basic concept i am trying to do, is simply generating a signal that i can adjust from an arduino due's DAC pins.
I need to able to adjust it from 0-10V. I have configured the DAC on the due and i have measure the output so i know that is working as it is suppose to.
Now i need an OPAMP circuit such that i get the voltage i need.
Here i found this dongle:
https://www.botshop.co.za/product/lm358-amplifier-module/
I also found the schematic diagram for the dongle:
So i have ordered all the components home, and i have tried to configurate them in the manor of the diagram, but as it is not working - i am pretty sure that i much have done something wrong ^^ btw i have no included the "led" in the beginning of the system. but i am pretty sure it doesnt have an effect so?
So currently i have attached the GND and VCC to a DC power supply, OUT to the oscilloscope and IN are coming from my DAC pin on the arduino.
When i send a signal on the arduino, i see a minor spike on the oscilloscope, which then decreases rather fast again ( i can show image if that would help ?) and in a similar manor when i turn off the DAC signal, i just get a negative signal that goes towards"0" again.
hexreader
Joined Apr 16, 2011
619
Quote from the link you gave....
" Note: this version does not support DC signal amplification "
You must feed the device with AC, not DC levels
Try writing code for a loop - maybe something like:
Set DAC level 1
delay 1 ms
Set DAC level 2
delay 1 ms
jump to start
This should give approximately 500 Hz square wave at DAC output, and amplified output from your amplifier with possibly a little distortion.
OPTSimon
Joined Mar 24, 2021
33
Yes but when i am "feeding" the IN with the DAC output on the arduino - it should also be getting AC ?
The VCC and GND should still be DC supplied right?
- Since it is supposed to work with arduino, and the common outputs on the arduino are DC
Ya’akov
Joined Jan 27, 2019
10,370
You need to supply the amplifier with AC and the rails with DC. VCC is DC.
Can I ask what you want this circuit to do? I mean, how will it be applied?
OPTSimon
Joined Mar 24, 2021
33
Okay then i think i am doing that correct - Since the IN which goes to pin "2" on the OPamp are the AC input from the DAC.
Yes ofc - basically i want to do some external signal modulation with one of my optical components and currently this lab doesnt have a frequency genetor, so after trying outwith the amplified signal(but just a digital pin from the arduino), i found that it would work, i just required a higher output( hence the OPAMP ).
I want to send a short pulse to my equipment which then will activate it in the duration of the pulse. But the output of the equipment is equvialent to 0-100% depending on the 0-10V that i supply - so if i want the 100% output i would need to supply it with 10V in the duration etc.
- i dont know if that makes any sense ?
OPTSimon
Joined Mar 24, 2021
33
Ya’akov
Joined Jan 27, 2019
10,370
You want something like this: https://www.amazon.com/KNACRO-Voltage-Module-Converted-Voltage/dp/B07GSTBTBZ
OPTSimon
Joined Mar 24, 2021
33
A DAC is a Digital to Analog Converter. It takes a digital value and outputs a corresponding DC voltage.
wow okay, i completely missed that - i though it would be AC output.
But okay, then it suddently makes alot of sense that it doesnt work.
I presume its the OPAMP only works with AC current right ?
Ya’akov
Joined Jan 27, 2019
10,370
OPAs do a lot of things, but I linked to a PWM driven module that produces 0-10V above. This is a much better solution. 0-10V control is standard with PLCs and automation and using an amplifier is a dodgy way to get the varying voltages you want.
OPTSimon
Joined Mar 24, 2021
33
Is it still possible to control the module you sent here with the arduino ? since i want to trigger it in "intervals" / short bursts?
Ya’akov
Joined Jan 27, 2019
10,370
hmm i though about something like that, but when i want to suply the 0-10V steady for example 1sec or i wasnt sure it would work with PWM
What is the maximum acceptable stability and slew rate? What is the required precision and how fine does the control have to be?
Ya’akov
Joined Jan 27, 2019
10,370
Given the relatively high operating frequency of the PWM input I think the desired voltage would be available very quickly. Only if this was timing critical in very small fractional seconds would I expect a problem for you.
OPTSimon
Joined Mar 24, 2021
33
hmm in the equipment manual, there arent supplied much information about it - https://www.thorlabs.com/drawings/9...-D98E-2340-AE325E9445D08FC1/KLD101-Manual.pdf
where i want to use the EXT IN.
I want to trigger it in durations of 20ms to maximum 1 sec. So i would say rather fine, and its very important that its "on" in a similar manor each time, else i wouldnt be able to compare my results on the other end.
Ya’akov
Joined Jan 27, 2019
10,370
Given the 1-3KHz input to the module, I don't think 20ms would be a problem at all. As far as repeatability, you'd have to test but I would expect it to be fairly good.
OPTSimon
Joined Mar 24, 2021
33
Okay, i will look into that option then, just have to find a module that are in europe - so i wouldnt have to wait that long for it tho.
