banana powering 5 molex connectors question
yef smith
Joined Aug 2, 2020
1,479
Hello , i have 5 molex connectors as shown below.
i need to feed them all from a single banna connection,Is there such acomponent which splits into 5 banana DC power?
Thanks.
dl324
Joined Mar 30, 2015
18,463
How many pins do you need to connect on each connector?
Molex connector isn't very meaningful. Molex makes a lot of connectors.
Assuming 0.025" square pins, you're probably going to end up making your own splitter. If you don't have the terminals, housings, and crimper to make your own DuPont style female connectors, you can cannibalize some ready-made. Solder them to a cannibalized banana plug with stripped wire lead.
If you're planning to draw 3A from each connection, you're probably going to have issues.
