Hi I'm going to use the BAJ0BC0WT voltage regulator and I am a little confused on the datasheet recommended circuit https://www.mouser.com/datasheet/2/348/baxxbc0-e-1874116.pdf.
in the circuit it looks like pin 1 controls if the regulator turns off or on, which I could use, but looking at the circuit it looks like it requires a little voltage to turn it on. Is that correct?
